Drum Sanders
AZ in Colorado Springs
Anyone have experience with any of these sanders? Looking for reviews from people whio have used these machines:
Jet 649005K
Jet 1632
Grizzly G0458
Thanks in advance
Andy
Drum Sanders
Jet 649005K
Jet 1632
Grizzly G0458
Thanks in advance
Andy
Re: Drum Sanders
Bob
I upgraded to the Jet 22-44 Pro 3HP, 1Ph, DRO, Tables and Casters about 1 year now I would advise against the 120 VAC 1.5 HP one you are speaking of. I found it not to have the power needed to do wider then 12" boards
Re: Drum Sanders
Larry in nw ohio
Robert I know you didn`t ask about these but I`ve had a 25" woodmaster sander over 10 years now and I really love it and wouldn`t look at anything else, and they are USA made in Kansas City. You bshould at least look if you didn`t. Larry
Re: Drum Sanders
Bob
Hi Larry, I was not the one that posted the question but thanks I have the 22/44 Jet Performax I do a lot of tables over 30" and the 22/44 does a great job.
Bob
Re: Drum Sanders
Larry in nw ohio
Robert I do not want to sound like I am putting down any sander. If a person has a certain sander and likes it then it`s a good sander. But if you never checked out the woodmaster then I think you may miss something. I just checked, www.woodmastertools.com, and they have up to a 50". I`m just saying a person should check out as many of something they are looking for as they can, because if they don`t then they may miss something. Have a good day and stay safe. Larry
Re: Drum Sanders
Bob
Actually before I bought this one I did look into Wood master. Good machine and I have nothing against them it was just not for me and to much weight. To each there own.
Re: Drum Sanders
Dave Paine
I have the Performax 1632 which is now sold as the Jet Performax 62004K. I cannot easily see how this differs from the Jet 1632. Perhaps Jet is phasing out the Performax brand.
At the time my model had 2 1/2in dust port. The first thing I did was to remove this and add a 4in dust port which is now standard.
I have had my machine for at least 5 years. Not sure when I purchased. I got this from Woodworkers Warehouse, so this was before they went out of business. I just looked this up. Went out of business end of 2003, so my machine is at least 9 years old. Still looks like new.
Another reply mentioned about the low power. I think my machine is 1 HP. The latest model is 1 1/2HP. Even with the larger motor, these units are sanders not planers. I have found taking off less than 1/64in in a pass works without tripping any breakers. Too think a pass on a wide board and my circuit breaker will trip.
I also set the belt speed to between 40 and 50%.
Drum sanders are famous for creating heat, even with light passes. I found it too easy to mess up a wrap to the point where I could not clean off the "streak" of whatever melted. The streak would then cause the next pass to have a burn mark.
I solved this by switching to Klingspor blue zirconia abrasive. Higher price, but well worth it. I finally get full use from a wrap. Rarely need to change, and easier to clean. Much less heat. If you get a drum sander, I highly recommend this abrasive.
Changing wraps is a pain. I buy the bulk rolls of abrasive and cut my own wraps. This is easy. Getting a new wrap on can be a pain as you will find out. Not easy to get fingers into the end of the drum to hold the spring clip open while pushing the end of the wrap in place. I even bought the special tool. This did not help me.
I do not use my machine as much these days mostly due to being unable to solve how to prevent a "dip" in the middle of a board. No matter what I have tried the middle of a board is slightly thinner than the ends.
I tried lifting the end up on the way in and out, but nothing seems to fix this issue for me. These are not long boards, perhaps 12in - 20in. I do not have the table extensions, but for such short boards, they should not be needed.
So these days if I use the machine it will be for rough preparation, perhaps after gluing up a board assembly.
The JoeWoodworker site (www.joewoodworker.com) has some good tips on alignment, tuning. One tip I adopted was to change the alignment screw and spring to be screw and locknuts. This was a good idea. Easier to adjust and easier to keep from moving.
Most of my sanding duties these days I do on a FlatMaster, which is a type of drum sander with the drum under the table.
Re: Drum Sanders
Bob
I bought the Jet 649600 Model 22-44 Pro 3 Drum Sander and its been a dream I had to over come a learning curve to get it to act right. installing the paper and to stop it from burning the wood was a problem for me as well. For one thing I was under the assumption that the feed conveyor was controlled to speed up and slow down depending on the load from the drum and if that's true I have not seen it work. I don't sand below 180 grit all I look for is to level the board (most boards are 24" to 32") then I use a smoothing plan or card scraper to finish up then apply my finish. Its great for figured wood as with a planer you get tare out. If I have to dimension lumber I re-saw slightly over size then finish with 60 or 80 grit depending on how much I have to go then change to 180. I also use the drum sander for veneers but never go below 220 grit.
Re: Drum Sanders
Bob
"Changing wraps is a pain. I buy the bulk rolls of abrasive and cut my own wraps. This is easy. Getting a new wrap on can be a pain as you will find out. Not easy to get fingers into the end of the drum to hold the spring clip open while pushing the end of the wrap in place. I even bought the special tool. This did not help me."
I had the same trouble and was unable to make the little red tool work so I posted a thread on Lumber Jocks and kept trying I final got the hang of it and thats all I use not when changing belts. takes me under 5 min and never had another problem since. I will try your recommendation on the Klingspor blue zirconia abrasive belts. I still have a lot of bulk rolls left though but you are right the cheep paper loads up quick and you have to dress the paper with a big eraser cleaner.
Thanks for the tip
