Does (or Will) Anybody Make This Tool?
Lee Gordon
Lee Gordon
Judging from the number of stores and internet sites that sell coffee and supplies for Keurig coffee makers, it seems to me there would be a great demand for cabinet makers to build racks, slide-out drawers, shelves and other holders, especially designed to accommodate K-Cups.
So it seems to me, there would be pretty good demand for a special tapered drill bit, plunge router bit, or perhaps a rotary rasp shaped like one of these.
I've searched online and haven't found anything. Does anybody know if such a tool exists? If not, I think it would be a good product for a company to make. (Lee Valley, perhaps?)
Re: Does (or Will) Anybody Make This Tool?
The Tool
Would be called a "tapered reamer". You'll have better luck finding one to the size needed at Reid Tools, ENCO, perhaps McMaster-Carr.
Procedure will be to drill the smallest diameter then get the reamer that matches the diameter you need/want at the highest point. You should figure to leave the cup rims proud of the surface by 1/4" or more
A piece of tooling that big is gonna cost you, so I'd try to do some real market research before making the investment.
Or,
Bruce, a MN Galoot
you could grind the correct profile on a big spade bit and use it in a drill press.
I have a number of tapered reamers - but I don't know if the profiles are correct. The Lee Valley Pro Taper reamer is $42 or so and their others are about $20.
The mechanics reamers are meant for steel - but they work very well in wood. They can be a bit pricy.
Why would the hole need to be tapered?
Dave Paine
I think making a straight hole would work just as well. Just select the diameter. Should not be a problem if the lip is proud.
Re: The Tool
My tiny (really tiny, think small) experience with this type of thing is that to do a nice job you need some serious tooling (bit, reamer, whatever and a serious machine to run it and serious clamping to hold the piece of wood absolutely still. Without every thing tuned up and running perfectly, you get chatter and the holes look like crap.
My question is why taper the holes? Nobody but a wood worker would care. Figure out how deep you want the holes and what the diameter would have to be to let the cups "settle" in at that depth. Or just drill holes in a thin piece of plywood or nice stock and have another "bottom" below it.
I used a 1 1/2" core box bit to create round bottom depressions in a jewelry box. It had a half inch shank and I used a plunge router and massive blocking to hold everything still. It worked well enough, but it tended to burn the bottoms of the holes.
Besides...
George Colonel's Workshop-Havertown PA
Good Afternoon Coffee Drinkers,
All coffees, when brewed, conform to the inner shape of the pot! DAMHIKT.
George
I'd look for...
John in NM
Some kind of carbide insert tooling. By the look of the thing, the cutter would need to be big, and that is where insert tooling would really pay. However, I agree with the others who've pointed out that there is no need to taper really. The other way you could approach the problem is to have a thin sheet metal plate with the holes cut in it, captured in whatever sort of woodwork you wanted to do. Less than 1/8" and you wouldn't even notice if it were tapered or not. For that matter, you could probably use 1/4" baltic birch instead of metal, still wouldn't notice that it was a straight hole.
Jim DeLaney, Austintown, Ohio
Re: Why would the hole need to be tapered?
The hole doesn't need to be tapered. A 1¾" hole works perfectly. I've made several small drawer units that have ¼" plywood 'platforms' for the drawers, with the holes spaced on 2¼" centers.
Sorry, no pix, because I've given the drawer units away, and don't have access.
Why holes?
Pat Evans
I've seen a shallow drawer unit that sits beneath the coffee maker and has divided drawers with slots for each flavor coffee. Works fine without individual holes for each cup.
A.J. Hamler
True, but...
A.J. Hamler
Yeah, those cups would rest in just about any hole, and they do have a prominent lip if the holes were drilled large enough for the K-cup to go all the way down in and rest on that lip.
However, that would require large holes and a lot of stock being removed from whatever workpiece you drilled the holes in, with not a lot of stock left between holes unless you spaced them out (which would mean either making the project larger, or keeping it the same size but you'd have room for fewer K-cups). A smaller tapered hole could support the K-cups fully below that lip without the need of removing so much stock.
As it happens, I did some experimenting with this a couple months ago when I was trying to come up with a good plan for a K-cup cabinet. A non-tapered hole allows the K-cup to wiggle, and it doesn't always rest vertically in the hole -- it'll be angled slightly one direction or another. Sounds like a bit of a nitpick, but in the workpiece I experimented with (16 K-cups in a 4x4 grid), nearly every cup was at a slight angle. Looked really sloppy.
Ideally, a tapered hole that supported the K-cups a bit more than halfway up would be perfect -- the hole would be sized such that there is plenty of support stock around the holes and still be able to pack a lot of cups in, plus the tapered sides would keep the K-cups perfectly vertical.
Cheap Solution
Make [turn] a tapered chunk on a 1/2" metal stud that you can chuck in a drill press. Apply sticky-back abrasive (say 60-80 grit) to the taper. Now you can ream your holes just as you wish. Total cost (not including the lathe) about 15 cents.
Re: Why holes?
larry in nw ohio
After reading Pats post, I had a brain fart. I wonder if an egg carton holes would work. I`d try one but we don`t have any right now. They might fit right in. You could trim it out and maybe spray it with some of the spray that leaves a fuzzy layer on the carton and then out them on the bottom of a drawer. Or maybe drill holes in a piece of wood sothe cups just fit the holes when the board sits on the bottom of the drawer and the cup sits on the bottom. Good luck with whatever you do. Larry
Paul Woolson
If you are really dead-set on boring these tapered holes, you might check our orbit tool works. I've had them make some custom profiled router bits. They do great work.
Lee Gordon
Re: The Tool
Lee Gordon
When the thought first came to me I did check out tapered reamers but all the ones I saw, including the ones Lee Valley sells, have a much smaller diameter at their widest point than even the narrow end of a K-Cup.
Lee Gordon
Re: The Tool
Lee Gordon
The answer to "why taper the holes," is "why not." I realize that it's not entirely necessary and that straight-sided holes will work, but as members of this forum know, probably better than most people, not everything woodworkers do is strictly utilitarian. Some things are for aesthetics, and some things are done just because it feels right.
As AJ has pointed out, the cups sit better (straighter and more evenly) in tapered holes. Having a tool to facilitate that process would just be another option. And we all like having options.
AZ in Colorado Springs
Why not cut an appropriately sized (it could be a bit undersized) hole with a hole saw, then use a chamfering bit in a router to cut the taper? You'd need a second board, with a slightly larger circular hole, to guide the router bit (fit a guide bushing to the router).
1) Mark the center of each hole; 2) mark the locations for the pattern for routing the chamfer; 3) cut the hole using the hole saw, 4) rout the chamfer.
Chamfer bits are available at many angles (not limited to 45 degrees). Less elegant than using a single tool, but probably cheaper. And, a more flexible process if you decide to change the hole size to accommodate different items.
Just wondering, I have a variable Heavy Duty circle cutter made by General tool - (I picked it up at either an auction or yard sale several years ago). It uses a standard 1/4" square cutter. I think you could grind the taper you want on the cutter and use it in a drill press, I wouldn't want to use it tapered for material much over 1/4 thick, but it sure looks like you could do what you want if you sharpen it well so you don't get too much tear out. Your not really wanting a lot of taper to match the cups.
