Lock 'em up!
Stephen Kirk
I haven't had a lot of time to work lately, but I wanted to do something. I also had Tim Detweiler's book Making More Wooden Locks. So, I figured that'd be fun. This is the first one and supposedly the easiest. I had wanted to do some of these to get familiar with the concepts for locks and their mechanisms. I was not disappointed. Going from larger furniture down to this is a challenge and locks require a lot of fine tuning, plus jigging to make small cuts. My lathe definitely came in handy to turn some of the smaller parts. The book calls for making the shackle from one piece, just cut out the candy cane and then round it over on a router. I did this with the first, and that process is nerve rockingly dangerous (even with push blocks to keep my hands away) and it wound up too small. Plus, it would have had vertical grain right at the top and could easily break. So, I turned two dowels and turned tenons on them, then made a piece for the top of the shackle with holes for the tenons, cut the curve, rough routed it to remove some material then finished on a sander. The shackle isn't perfect, but I liked the slightly bumpy feel of it. It does indeed work. This one is my prototype, now that I know how it goes I can work on other varieties. I'd like to start incorporating locking mechanisms into furniture designs. I left the retaining pin (the little nobby bit at the bottom) loose since when people see it they want to know how it works.
I'll sand off the numbers and put nice ones on before finishing. I'll probably just wipe on a coat or 3 of poly, this doesn't need tons of protection.
