drying lumber
drying lumber
drying lumber
Philip Duffy
Just sawed 2 magnificent white oak logs from the hurricane that blew thru here last Oct. Planks are mostly 6/4, 8 to 15in wide and 6ft long. I have it all properly stickered. Do I need to spray for bugs? What is your experience and what did you use? All help appreciated. Many thanks, Phil
Re: drying lumber
Re: drying lumber
Keith Newton
It is hard to spray for insects once they are in the wood. Leaving it in the log for this long, is an invitation to them. After they are in, the best way to kill them, is with heat. I have forgotten what the magic number is, but you can google to find it.
The sprays only treat the surface, and are best for prevention, IMHO.
Re: drying lumber
Re: drying lumber
I dislike spraying for bugs as I don't like milling pesticides. The stuff is poisonous.
I have sprayed sodium borate on wood (2-5% solution in water).
I have bagged wood with plastic bags (55 gallon) and dropped a few chunks of dry ice in with the wood. The dry ice (frozen carbon dioxide) sublimates from a solid into a gas. The CO2 suffocates the bugs quite nicely and then dissipates. if you have the heavy duty polyethylene, you can make your own "bag". It needs to be reasonably air tight at the bottom. The dry ice method takes a day or two. It will kill active bugs that are "breathing".
Kilning the wood definitely kills the bugs and is highly recommended.
Your choice.
Re: drying lumber
Re: drying lumber *LINK*
JS Direct Wood Routers
Hello. New to the forum.
I heard once about that dry ice method, and thought it was a joke, but now that I've heard it again, maybe I was wrong and might have to give it a try next time I need it. Thanks!
Reviews of the best wood routers
Re: drying lumber
Hard to say.....
Bill Tindall
I have seen powder post beetles attack white oak sap wood in storage. And I have not seen attack in other times. I spray everything I store now days with persistent insecticide. It all goes out with the planer shavings. A volatile insecticide will kill the critters in an infested board.
Just curiouns, why 6/4? I never had a call for 6/4 lumber in 25 years in the hardwood lumber business.
Re: drying lumber
Re: drying lumber
Robin Corell in Atascadero CA
if you just milled the wood this is when you want to treat it with sodium borate. I don't treat the wood I mill but I have a lot of walnut and the bugs don't bother it.
This is a tough time of year to be milling white oak for air drying. keep it out of the sun and you want the air to circulate but you do not want the wind to blow through the pile.
Robin
Re: drying lumber
Re: Hard to say.....
Philip Duffy
Bill, the 6/4 comes from the fact that I needed to cut a few planks for bowls, and other projects, but it also allowed us to "get off the saw" a whole lot quicker - -- we borrowed the time. Lots of other sizes cut as well, including a bunch of bowl blanks and 2 12/4 pieces for smaller bowls. Phil
Re: drying lumber
Re: drying lumber
Philip Duffy
Thanks, Robin, good advise. Phil
Re: drying lumber
Re: drying lumber
Phil, You might go to woodweb.com and rummage around for advice on drying white oak. I have dried lots of walnut, Cherry, poplar and a little gum, but not oak. I stickered mine, some of it in an open shed o a barn and some of it in my driveway under a tarp. It has worked well, but my understanding is that white oak is much more difficult to dry than any of the ones I have. And thicker is harder than thinner.
