Air Compressor
Air Compressor
Air Compressor
chris prieechenfried
I'm a thankfully retired Enginer (EE), who has fogotten all that motor theory that he learnt in the late 50's. Yesterday my long suffering, carefully maintained ( I can remember draining the water from it at least twice in the last 30+ years!!) Sears 1hp air compressor died, not a click or hum or anything. This morning i had a brief look. There is power to the motor, and the switch works OK. What do you think, my feeling is that I do not want it to be dangerous, and that probably the best bet is to buy a new one.
Chrispy
Re: Air Compressor
Re: Air Compressor
larry in nw ohio
I assume that it has a capaciter on it, that may be your problem. Take the motor apart and see if it may have points on the back side, they may be sticking open or dirt in them. Blow some air or clean the points since you do not any compressed air. They may be burnt some what and need a little fileing, very little. Try that it may work. Since it doesn`t work, your not going to brake it. Good Luck. Larry
Re: Air Compressor
Re: Air Compressor
Dean Johnson
Similar thing happened to mine. Replaced a couple of capacitors and we were good to go. Model numbers and google were my friends when I was looking for parts.
Re: Air Compressor
Re: Air Compressor
Personally, I might tinker with it, checking to see if it has a thermal overload (I have seen them open up just due to age), or open caps but I would do it after I went and obtained a new unit :>). At 30 years with no maintenance, I am sure the tank isn't in the best shape and probably the cylinder, valves and rings have just a bit of wear. I sure wouldn't put more than a very small amount of money in it at that age. Gives you a good excuse to replace with a nice 60 gal unit that will allow you to run power tools and spray with the pro's. ;)
