Re: Foam core
TomD
"If 'glass is strong enough consider using foam for the core instead of plywood. You can add ribs of foam to give strength."
Others have said not to do this, but it will work well with boat grade foam, though that is not always cheap either.
"Strip canoes don't rely on the stripping for strength, just shape."
That is a misconception, the strips are critical to strength, the amount of glass they are covered with is not strong enough to replace the interior strength provided by the wood, and the weave of the glass is relatively open compared to what is really needed. That said, the strength is mostly longitudinal, and that means the wooden strips would be more appropriate in a spar configuration like a mast or a beam.
One thing one can check for oneself is the success of all glass and foam canoes, they are often horrible since the weight budget does not allow enough materials even to keep the skins fair.
There are also quite a few things that can be done to improve both wood contribution, and glass contribution, but most people are not willing to do them on strippers since that is mostly a look project for makers, not an engineering one. It is also easier to improve heavier loaded structures since the weight budget provides a lot more alternatives.
"I wonder how strong FRP is to crushing and puncture??? I'm using it to panel my camper for other reasons."
Not as good as some other alternatives, but good at the price. I have seen studies done dropping ball bearing on sheathed panels, and glass polyester is the low end. Good epoxy like west is better (cheaper epoxies can be sub polyester). Kevlar is better still. The resin is quite instrumental in absorbing impact of other compression loads.
On another subject, mat polyester is garbage. It drapes well, and makes nice structures for speaker enclosures that get carted around in cars, but it is a horrible structural material.
