What's the advantage to HVLP?
Tim Greif - West of Chicago
I've been spraying paint for a number of years, mainly cars, boats, motorcycles and brass restoration. Very rarely furniture. I have a normal no-name production gun, a detail gun, Pasche air brush and a "Critter". Each has it's place. What possible advantage do I get with an HVLP conversion gun? Does it completely eliminate overspray? If not, why bother? Are there other advantages?
Just looking for tha facts, maam.
Re: What's the advantage to HVLP?
Robin Corell in Atascadero CA
HVLP does not eliminate over spray but it reduces it and it really cuts down on the amount of fine atomized mist that fills the air when paintng something big, like a car. They also take a bit less CFM of air to lay down the same amount of paint.
Robin
The facts as I see them`
Bill Tindall
I have, and now never use, an Appolo HVLP and two DeVilbiss conventional guns which I use regularly.
1. Were it not for EPA regulations in places like CA they would never have become widely used. They reduce overspray. I have heard number like 50% reduced to 30%. That seems about right in my hands.
2. They are nice for the insides of things and corners. Less bounce back.
3. They are harder to learn to run right. More picky about optimum distance and adjustment.
I bought the Apollo thinking it would lessen the cost of expensive conversion varnish applications. I am sure it did but it was annoying to use compared to conventional. Too picky about getting things just right to get a good finish. Had I learned on the HVLP I would be satisfied with it.
Re: Agree with Bill
I have a couple of (admittedly cheap) HVLP conversion guns and a couple of Binks conventional guns + some cheap conventional and airbrushes. The ONLY advantage to the HVLP is the fact there is less over spray and "bounce back", therefore they do use less material - I think the 50% claims are WAY overstated - I do use the HVLP when spraying into a deep box or when fixed shelves cause a lot of bounce back. But the conventional guns IMHO do a better job of laying down a smooth level film with less hassle. I would never purchase an expensive HVLP unit as I don't think they do as nice a job and the material savings I would see would never pay back a unit. Possibly if I had a full time cabinet shop (with several employees) where I used gallons a week it might be economical to use one.
money savings
Dick Coers
If you've sprayed much automotive finish, I'm surprised why you would ask what the advantage of using HVLP would be. They transfer a lot more material to the work than conventional guns. Automotive finishes are so expensive these days, that even saving 30% of the material would be a big deal. I'm a big fan of HVLP and I have older Binks and Devilbiss guns. The new guns are even better, but only comparing a cheap HVLP to your old conventional, is like saying I prefer my old Powermatic table saw to a new high tech Craftsman.
Re: money savings ??
Dick, I can't argue with your statements, however I don't spray cars - don't have any booth or drying area and don't intend to do any. I have in the past (long ago) but now only do woodworking. I may spend $300 maximum on finishes a year. As I said I am very comfortable knowing I can get a very good finish with the Binks guns. Even if I could save 50% (which I highly doubt the actual savings is anywhere near that), it would take several years to recoup the $1000 or so required to purchase a multipurpose turbine HVLP system. Then there is the learning curve on tip use - thinning etc and I don't really want to undertake that at 71 years of age for absolutely no improvement in my woodworking. I have never seen any claims that HVLP does a better job in applying finishes. In fact I have seen many that believe the conventional units are better. Airless systems also do a real good job and save material (even more IMHO than HVLP) but also have drawbacks. I am fairly experienced in their use as I set up a booth and system for applying a sealer to printed circuit boards in my working career. The last time I was in an auto paint booth in my locality - about 8 years ago to have my Van repainted, he was still using conventional guns. I agree with Bill that if California hadn't required the emission crap, HVLP would not be very big.
Jason Waters
Auto Makers started using HVLP type systems prior to EPA requirements (which only required it in the last few years for Auto body shops). However, nearly every Auto body Shop uses HVLP. A $500-1000 HVLP gun (not the turbine type) is recovered in just a few cars. Auto Paint is really expensive, to the tune of about $500-600 for the paint and primer for a single car anymore. Yes, there is cheaper stuff out there, but not the good stuff. It is about saving money in this business.
As for applying stuff that's $20 a gallon, that's different economics. You have to use a lot of paint.
I'd agree it's not a 50% reduction, but it is a 20-30%.
Comes as a package.
DizD
For a home shop with no or minimal air compressor, HVLP unit enables you to spray without investing in a larger compressor. I have been doing 3 to 4 large pieces a year and my HVLP unit has been a good fit for my shop.
Thanks guys.....
For the little amount of use I have for a spray gun, it sounds like I'll just stay with what I have for now. Thanks for the input.
Tim
