We value your privacy.
In your post, you say that you are going to use pine or poplar to edge your sheets. What exposed edges is your question directed to? You can glue a strip of pine or poplar on all the exposed edges. Make the strip a bit wider than the 3/4" ply. Then, you can trim it flush. I've had good results simply using masking tape strips to "clamp" the strip to the ply edges.
Lynn, if you want the edging anchored, you can cut it "T"-shaped and cut a dado in the edge of the plywood. A good snug fit may allow you to forgo the masking tape when gluing it on. I've had good luck with this method.
Dang Yonak, I hope you don't make all aspects of your life harder than it needs to be, like this.
I just rip 1/4" strips, then glue and staple it on, then spackle the staples. Once it is sanded and painted, nobody can tell one joint from another, but I can be sanding while you are working on getting through that tongue and groove.
This is not what anybody thinks of as fine woodworking, so making it better than it needs to be, just takes longer. With more than 35 years as a professional cabinet maker, I have never had a glue line failure on this kind of edging, so until I find something faster, which is as reliable, I guess I'll stick with it.
Iron on edging is faster, but through the years, I have seen plenty of problems due to using that, so I'll leave that to others.
I glued plenty of oak edging onto plywood, without biscuits or anything, by clamping. I use about 7/8 wide, and then flush trim with the router. Makes a nice edge. I usually make mine about 1/2 thick though, clamps better. that's for a stain/clear finish.
If you are painting, you can also use woodfiller or spackle on the edges, prime, and sand. If I am painting, I usually use brads or nails as mentioned if I attach an edge. usually when I do this, it's a two inch front and back, to stiffen a long shelf.
I've used iron on edging a bit too, but it can be tricky as mentioned.
I've had good luck with the iron on veneer for similar projects(shop cabinets). I believe you can find it in rolls at Lowes and Home Depot, etc. I used it for my router cabinet and it has worked great even after the abuse that cabinet receives.
As these are supposedly cabinets inside closets...not that they should be of lessor quality, the type of usage I suppose they will get is less then say a Kitchen cabinet
I would consider the iron on edging
I have used this on plywood pieces that are more visible and higher profile then "closet" cabinets with no issues. The glue strips are real wood will take stain or paint, you can get many species of edging for a perfect match and its easy...everyone has access to an iron and a utility knife.
Oh yeah and its three times faster.
My experience is glue on ( which is used frequently in Professional Cabinets ) is durable enough, faster and perfect .....especially if painting .
What kind of closets and cabinets? Will there be a door covering them? Even if you are painting, you might consider upgrading the look to use a routed front edge molding and molding around the sides. The little room I use as an office had an unfinished 6 ft. inset for a closet when I moved in. Since I wasn't going to use it as a bedroom, I made it more functional and built 2 base cabinets with file drawers and 2 upper bookcases. All casework (and shelves) is plywood. Shelves are edged with 1" thick strips that are about 1" tall, too. They help give strength to the shelves besides looking nice. My molding happens to be solid cherry, but you could use poplar and paint it or even stain it.
