Drum Sander
Lewis Dodd
I am considering buying a Grizzly 1066 24" drum sander.
What negatives about this , other than being an import?
Drum Sander
Lewis Dodd
Re: Drum Sander
Nelson
Sorry but 99% are imported..
Re: Drum Sander
Larry in nw ohio
Lewis I can`t tell you about the Grizzly, but I have had a Woodmaster for over 10 years and love it. But of coursr can not compare it to any other. One thing it has on the grizzly is, it is made right here in the USA, in Kansas City. I even went there to see where they make it. It was very interesting, the place where they make it is inside a hillside, from where some kind of mineral was mined out of. They have a lot of industries inside of these abandoned mines. Anyhow I like my sander, the motors are even made here, I think they have a Baldor. Good Luck Larry
Re: Drum Sander
Michael Wilkins
These can be a great time saver; I use mine after the wood is planed to get rid of the planer marks. The ones that look like a wash board. Do no try to use it as a planer; if you do you will be dissapointed. They
are not designed for that purpose. Consider it the initial part of the finishing process. It will reduce the amount of sanding you have to do, depending on what grit you equip your machine. You can put a on 36 grit paper to run rough lumber through, but you will need to change grits again to get to a finer (100 or 120) to get a decent working surface. Not worth the trouble.
As the other respondent stated, 99% are made in someplace other than this country. I got the Woodtek 25" dual drum sander from Woodworkers Supply; but if you look at the specs and design of this machine, it is just like the offerings from Steel City, General and Laguna. Same machine/different paint job.
Also remember to take light cuts.
Re: Drum Sander
Dave Paine
This appears to be a nice machine.
I have a number of Grizzly machines. Normally good value for the price. I preferred when Grizzly was manufacturing in Taiwan. Many of the machines are now being manufactured in mainland China.
I have a Performax 16/32, so can only comment on features common to drum sanders.
Dust collection is a must.
The G1066R is a fixed feed rate. The G1066Z is variable feed rate. My Performax is variable feed rate, which I prefer.
As another person stated, light cuts are recommended. These are not power "planing" machines.
Drum sanders generate a LOT of heat at the drum, the light cuts also keep the heat down, but with oily woods, one pass can result in a mess on the sandpaper. Sometimes possible to clean off, sometimes can mean the wrap needs to be discarded. I had some wraps which were ruined in only a few passes. If you go to any showroom where they have drum sanders operating, you will typically see some messed up abrasive. Not worth changing for the demo.
I switched to the Klingpsor "blue" Zirconia abrasive. Highly recommended. This reduces heat build-up and now I get much more use out of a wrap. Very much worth the extra cost.
I buy the rolls and cut the wraps as needed.
Changing wraps can be tedious, so I use single 80 grit.
I use the drum sander to get a surface somewhat true/flat. My unit tends to sand the middle more than the ends so if I make too many passes I end up thinner in the middle. I am not sure if this is due to operator or the design of the machine.
I normally finish my sanding to finer grits on other machines or ROS.
If you are within driving distance of a Grizzly showroom, it is recommended to pick up the machine. Some people have reported the freight from the Grizzly showroom to their home can result in damage. The units are better supported on the shipment from Taiwan/China to the Grizzly showrooms.
Re: Drum Sander
andrew nistock
Lewis,
Don,t know if this is true in all cases but I have a Woodmaster Drum sander and I love it. Also excellent advice and quick service from Woodmaster people. As far as Grizzly is concerned I do have a couple of their machines. Overall I am satisfied with the performance of the machine but my sticking point is the switches that Grizzly used on these machines. After a few years of service (table saw and jointer) the switches are getting so that they may have to be tapped a few times to get them to turn off. Also right from the beginning they needed a "harder" tap to get them to shut off. I have a 20+ year old delta table saw and the switch on that machine is a magnetic starter and all you need to do is just very lightly touch it and it turns on or off. Just my two cents.
Re: Drum Sander
Dick Coers
As my friend Terry as said, "I've sworn off anything from Grizzly with a cord." He had a metal milling machine that went bad, I had a big band saw that was not worth the value of the horrible cast iron in it. But if you must, don't consider the single feed speed. 36 grit requires a much different feed rate than 120 grit. Drum sanders get the abrasive back to the wood very quickly, and as mentioned earlier, make a lot of heat. I have a 16/32 Performax and love it for stock prep of figured wood for boxes and thin stock prep for shaker boxes. Running 100 board feet for a furniture project, no way.
Re: Drum Sander
Ryan
Be sure you get them to show you how to change the wrap. I've got a Steel City drum sander and changing the wrap is a real pain. Badly engineered. Took me awhile to figure out a few tricks to simplify things and even then the process is accompanied by at least a few swear words!
