Re: 1st table saw *LINK*
Dave Paine
You do not state the kinds of projects you want to do.
If you feel you will be doing a lot of cross-cutting then consider a sliding compound mitre saw.
If you will be doing a lot of ripping then a table saw is the way to go. I would get the biggest table size you can afford. Same for the motor.
My first table saw was a Sears "hybrid" a contractor type saw, but with the trunnions mounted to the cabinet and not the top. At the time (2005) it was made by Orion for Sears. Orion later became Steel City Tool Works. The link is the latest Sears offering. The granite top feels like this may now be Steel City model. Almost the same as my old machine, except mine was cast iron tope and had the Biesemeyer Professional fence. This was perhaps the best feature. This saw has 1 3/4 HP motor.
The motor was adequate, except for thick stock (> 6/4 stock) e.g., hard maple or cherry was too much, even though I used a thin kerf blade.
I built a much larger outfeed table around the flip-up table. For my projects working alone, it was a big help so that long pieces were supported after the cut.
I agree with the other recommendations to try and find a used machine. Better bang for the buck.
The fence can make a major difference in the performance of the machine. The contractor saws may not have as good a fence as the cabinet saws.
Some people like the Rigid contractor saw. I have not used one.
You do not state if this can be in a fixed position or needs to be movable. Even large cabinet saws can be put into mobile bases, you just want to do this during the initial installation.
My first saw was installed in a mobile base. The replacement is not. I do not often need to move the saw, only when ripping long boards, and the choice is move the tractor and bucket or move the saw. I now go with the former.
Other than the big box stores, it may be difficult to "kick-the-tyres" on a machine. If you are driving distance to a Grizzly Imports showroom, I highly recommend a visit.
Grizzly has perhaps the best price on the cabinet saws, and several models. Many people have Grizzly machines. I almost went with Grizzly for my replacement. I ended up with the new Delta Unisaw.
I have other Grizzly machines.
You mention needing to use a dado. I have a dado blade, but find that my preference is to use my router table. I can fine-tune the fence and depth adjustment better than on the table saw.
Also consider zero clearance inserts. This can save a lot of splintering of cuts, especially with plywood.
I would plan on dust collection. Cabinet saws have better design for dust collection than the contractor saws due to the latter having the big hole at the back to allow the motor to swing back as the blade is lowered.
http://www.sears.com/shc/s/p_10153_12605_00922116000P?prdNo=6&blockNo=6&blockType=G6
