Wide Sanding Belt
Larry
Does anyone know where I can get a 25x48 100 grit sanding belt? I going to use it for a conveyor belt for a drum sander.
Thanks
Wide Sanding Belt
Larry
Thanks
Re: Wide Sanding Belt
Richard McComas
Most abrasive companies will make any sized belt you want.
Re: Wide Sanding Belt *LINK*
Bob Entwisle in NJ
Hi Larry,
Looks like these folks will make up whatever you want.
I just googled 'custom sanding belt sizes' and this is one of the places hat came up.
I've no experience with them, and I'm sure there are plenty of other sources.
Ace Karner
these people are great to work with
http://www.industrialabrasives.com/industrial-abrasives-sanding-belts-standard-wide-sanding-belts-c-73_302.html
I would contact Klingspor - Click on marketplace on left side of this screen and select Klingspor. They are a sponsor of WoodCentral and have great products at good prices. They are the only supplier of abrasives I have purchased from for the last 4 or 5 years - never been disappointed.
Re: Industrial abrasives is best
Rick L
Local place, best prices, good abrasives and lowest minimum for custom sized belts. Compare the prices to anyones...
Where are you? there is an abrasives company near Petersburg Va that will make most any size you want.
might be a good idea to check around and find out what a standard size is and use the one that best suites you even if you have to change your design a bit. Could you buy a standard belt for a Performax or other drum sander? The local woodCraft store had one in stock for a 16/32.
Larry
I'm in Salinas Calif.
I could get a belt for you, but it would cost more to ship it to you than the belt cost. One of us is in the wrong end of the country. Bet you can find somebody a little more local. If not, let me know and I will get you the name and number for the people here.
I would still recommend finding a local supplier or better yet, use some sort of standard belt. I have to replace mine about every five years, so you want to be able to get a replacement when you need it.
By the way, you did not ask for design help but I would suggest you make the rollers for the belt fairly large. My Performax has rollers that are about an inch in diameter and rolling the belt around such a sharp radius over and over seems to be one of the things that accelerates the seam failing.
Larry in nw ohio
Larry Have you tried www.2sand.com they make special belts and will give a price right on their site. But they have a minimumorder of 60.00 but I don`t think they charge for shipping, I`m not sure of that. Also I just thought of a really dumb question. Would it possibly work to put say 4 belts of 6' X 48" side by side or would be not possible to get it to track correctly. I told you it was a really dumb question. I think I would try it just for the nuts of it. Good Luck Larry
