An idea for a short "screwdriver"
Bill Tindall
Tops on Period pieces are often screwed to a false top of a case, or at least a top frame. The problem is that there is scant room to employ a screwdriver, especially so to get enough torque to set the screw.
To the rescue, square drive screws and a 1/4 ratchet drive.
Re: An idea for a short "screwdriver"
AZ in Colorado Springs
You can do the same thing in a short space using a snappy brand countersink. I drilled the hole from the outside, then used a ratchet and socket with the snappy countersink from the inside of a short drawer to drill the countersink clearance for flathead screws to secure the drawer front.
Sears makes 2 little 1/4" hex-ratchet handles,
Keith Newton
One straight, the other cranked, which with a short bit, only requires about 1" or maybe less, over the head of the screw. They are nice little tools, for ~$10 each. I have both, and have had to use them both when nothing else would have worked as well.
Yeah Bill, I have also used my 1/4" air ratchet to set pocket screws. If you attach a 1/4" 6 point socket it will work with any of the screwdriver bits. I have a small flex (rubber) magnet that fits into the socket and holds the various drivers.
Jason Waters
Bill,
That's great. Nothing like using the ole noggin to solve a problem with the tools on hand.
I've used various setups like others mentioned too.
I have done exactly what you did many a time. Well, kinda, I never quite used that setup...
Jason
Dave Nichols
An even shorter way would be to use a 1/4" ratcheting box wrench with the driver bit. The total height would be about 1".
Bill, Here are a few more
Gary Smyth
I can't tell you how many times I needed one or more of these. House sales yet again. Except for the ratchets if they are over 50 cents I pass then by. They do come in handy in tight spots. The leverage is not good, but with practice, and occasionally a set of pliers the job gets done without damage to the wood. The screws suffer though.
The shortcoming of your examples
Bill Tindall
They don't provide sufficient torque to a slotted or Phillips to set a cabinet top to a frame or false top. The key to success is actually the square drive screw. The square driver does not have to be pushed hard into the head to maintain enough torquing force. Then it is just a matter of what can be used to turn the driver and any 1/4" wrench will do.
Bill,  You're correct.  I neglected to
Gary Smyth
include this gem. Available at many fastener stores a series of these (I believe that they come 1" to 6") will provide you clearance and do what you want to do.
NickinMass
Lee Valley sells (or at least they used to - several have fallen into the box over the space of various orders) a little ratchet set with 8 or so 1" screwdriver bits. A finger with some pressure over the center of the ratchet mechanism keeps most driver tips engaged, but as Bill said, square drive is the best (I buy only square drive screws unless availability or aesthetics dictate something else).
See LV 88K11.10 which includes....
roger lance
square drives.
Keith Mealy
My "most used" screwdriver set
http://www.amazon.com/GearWrench-85035-35-MicroDriver-Set/dp/B0062FSAVI
