Need advice on brad/pin nailers.
DouginDenver
Although I look for any excuse to buy a tool, I've somehow managed to do countless home improvement projects and build a fair amount of furniture without investing in an air compressor or nailer. Now I want to get one/two. I am installing kitchen cabinets that have a two-piece crown molding. Not to the ceiling, just around the cabinets. Main crown molding is 4" solid cherry going on good quality 3/4" ply veneer cabinets, solid cherry face frames. Second molding is a thin dentil molding that goes on a flat spot on the crown. I do not want to rent a tool because I want to take my time. I get confused because I'm not sure what size brads are best, and each nailer seems to mostly shoot one or two sizes. No. 6 finsh nails seem way too big for the crown, and it seems the dentil molding ought to be littte pins. I'll buy two if I have to. Any advice on what size shooters to get? Thanks.
Re: Need advice on brad/pin nailers.
Joseph Mulherun, Sr.
Doug, I bought two pin nailers and the pancake compressor from HF a few yrs ago and they have given me very good service. The larger one handles all nails from 1" to 2 1/14". Just do the periodic maintenance on oiling them regularly to keep the gaskets "O" rings slick around the plunger and you will do fine.
All total the cost for all was around $200.
del schisler
here are 2 porter cable nailer'w that works very well. I have the 18 gage the older style it work's perfect. here are the speck's check with the box store's or on line for best price's
18 Gauge 1-1/4-in Brad Nailer- BN138
Tool-free, adjustable nail-depth adjustment
Easy jam-release mechanism
Drives 18 gauge nails 5/8 to 1-1/4-in long
23 Gauge 1-in Pin Nailer- PIN100
Adjustable air exhaust to help maintain a clean work surface
Adjusts automatically for different fastener lengths
Uses 23 gauge 1/2 to 1-in long nails
Jason Waters
I have the following:
15 gauge Porter Cable Angle Crown nailer 2 1/2". Yes, it leaves a big hole, but I like it for baseboard, and painted crown. Stained crown on cabinets I might do something else, like attach it from the back unless it goes to the ceiling. It easily pulls base into crooked walls and crown into crooked ceilings. 16 gauge straight nailer tends to pull through sometimes, I don't even have one. If going to the ceiling, I'd use the 15 gauge and cover the holes.
I have a 18 gauge Porter Cable Brad nailer, up to 1 1/4. 18 gauge 2" tend to bend easily, and can blow out the side. I have used the Harbor Freight one too, and it's fine for homeowner use. I buddy has one, and it uses it a few times a year, no problem.
Lastly, I have a Harbor Freight Pin nailer for that fine work you talked about. I like it a lot, and it's been fine for the limited use it sees. I think I got it on sale for like $17.99!!! I wouldn't spend a lot here as I don't use mine much at all, maybe 3-4 times in several years. Harbor Freight has the pin nails, I have only one size as they are out a lot.
Nails can be expensive, but Harbor Freight is the best if they have nails to fit your nailer. Take the 20% coupon with you, as nails are rarely on sale, and on a $25 box of nails, it's like $5 off....
Larry in nw ohio
Doudin, No offence to the people that buy HF, but you need to watch what you buy there. I also buy things there, but I only do it like if I can not find what I`m looking for any place else, and depends on how much I`m going to use it. So kind of whtch what your buying and how much your going to use it. If you don`t know, you can buy Compressor, and 3 nail guns quite a lot on sale so look for them. Good Luck. Larry
Bill White
I use a 16 ga, 18 ga, and a 23 pinner. Pin nails are not for structural strength, just hold stuff while the glue dries (unless you're doin' really tiny trim on small projects.
My PC 16 and 18 nailers have been real horses. I clean and oil every day after they are used.
The 23 is an Air Locker. It too, has been a good gun.
I buy the nails from HF.
Bill
Another vote for BN138
Dave Paine
I also have the PC BN138 brad nailer and like it very much. I would recommend this to others.
I used the brads to hold pieces I am not able to clamp until the glue dries.
I am not sure if you were intending to hold up 4 in crown molding without gluing. If this is the case, you need a nail gun, or ideally small headed trim screws.
You would need something with a decent head to prevent the crown molding from drooping over time.
Depending on your desires (Do you want to get by cheap for a seldom used item or purchase something that you will use forever). I have 16 and 18 gage Senco and Porter cable nailer's. I like the rubber nose-piece on the PC much better _ already lost the Senco as it doesn't stay on as well. I also have a HF pin nailer, used it quite a bit before it gave me any problems, then spent an hour or so tearing it down and re-aligning the feed jaws. Works OK now. I don't use it often so have been well satisfied with the cost/performance ratio. One thing - you can buy the combo units - air compressor, and 2 nailers (usually 16 & 18 gage) fairly reasonable. If you want a compressor that will last try to find one that uses oil - the oil free units have a pretty limited life. I found a Hitachi oil type direct drive on markdown at Lowe's for about $150, works great. I have a 60 gal unit in the shop so only use it on outside jobs.
Jason Waters
Larry,
I agree you should watch what you buy at Harbor Freight. I bought one cord end to repair a drop cord (male end) and it's terrible compared to a nice Leviton or such.
I would probably stick to Porter Cable or similiar for a crown nailer, but the cheaper brad and pin are ok.
Also, check the refurbs available from CPO and like places.
Jason Waters
I agree on the combo deals, very good sometimes, that's what I started with.
NickinMass
I'd look at either a 15ga or a 18ga brad nailer for your main crown stock, and a 23ga pinner for your dentil molding. 23ga pins are great for thin moldings - no splitting, even near the end of stock, and they leave a very tiny nail hole that can be filled with a speck of colored wax in stain grade (I usually don't bother to fill the holes in paint grade stuff). They don't have a lot of strength, but I'm not sure that you need much strength for this application. If your crown is not too heavy, I'd go with the 18ga brad nailer, as it leaves a rather smaller hole.
Personally, I have a Senco 15ga and 18ga (oil free - love not having to oil them) and a Cadex 23ga pinner. I like both (although it can be hard to find parts for the Cadex), but they are not the cheapest.
