Anybody know what this is?
Henry Higginbotham
I'm pretty sure this one's not an army telephone or telegraph, and I'm also pretty sure the slick, heavy-duty toggle clamp is worth the two bucks I paid at a thrift store this afternoon, but beyond that I'm lost. The red stuff is some sort of cushioning foam. Looks like you'd clamp some round thing and then heat it up or measure its kilo-somethings (if you had the rest of it).
Re: Anybody know what this is?
craigd
craigd
It is used to change the oil filter on the Millennium Falcon.
No, no
Clamps the retro-turbo-encabulator for bench work. The cable is for the astral heat stabilizer, so you can test it "live."
Whatever it is, it's mystificating.
Re: Anybody know what this is? Nope..
Bob Entwisle in NJ
But it sure is a nice one!
Bob in NJ
John Luke
Heavy duty blood pressure cuff?
MRI machine for Lab Rats.
Dave Paine
Wow,for once I may get to provide an answer.
This is a hot press for mugs / coffee pots. My wife has a very similar one. Used with dye sublimation inks to transfer the ink from the paper to a film on the surface of the mug.
The toggle clamp is needed to provide sufficient force to clamp the paper evenly around the mug.
The cushion is to take up any space between steel collar and the mug.
The wire is for the heater which is a surface type heater.
Normally these would have a temperature gauge, at least my wife's does. The sublimation inks require a minimum temperature, e.g., 375 F.
Clamp the mug for a minute or so and then the ink and image is transferred to the mug.
If any interest I can post some pictures of my wife's unit and samples of the results.
In case you want to use this, the sublimation inks are VERY expensive, and require special ink jet printers.
Pic's of my mug press
Dave Paine
This is my wife's mug press.
This is how it looks with a mug in the closed position.
This is an example of the results. This is our young Dalmation male Ranger. Handsome fellow.
Once the mug has cooled the image is permanent. We put these in the dishwasher without and problems, other than if the mug cracks. :)
Way to go, Dave
Yonak
At this site, ask and you get an answer.
JMOHNIKE
back in the 60's we used them to roll a big joint. The were real common back then, this is the first one I have seen in many years.
Larry in nw ohio
JMO I thought I saw those somewhere, but I just couldn`t remember. Those were the good old days. Larry
BrianA
I'm not posting a picture of my mug!
Brian
JMOHNIKE
thank you
Thanks Dave. That makes sense . . .
Henry Higginbotham
Although I liked some of the other uses better. :)
Wow!
John in NM
I have to say, I am impressed that you knew what it was :D
Pretty amazing breadth of experience around here.
