dewalt 735 Planer Problem
John Truffa
I'm getting wood chips inside the planer housing. They are fouling up the chain that raises and lowers the blades. I've taken apart the fan housing and see no visible cracks. Looks like the dust is coming up from underneath the fan housing where it fits onto the motor. Any help would be appreciated.
Re: dewalt 735 Planer Problem
Larry in nw ohio
The exhaust fan, which takes the chips out, is more than likely plugged. Take the top off and youll see it. It`s the black circular housing on the out take side. Find where it sucks the chips up and just follow it and just check around that area and you`ll find out what happened. Good luck Larry
Been there. Done that.
What you have is probably similar to what I had.
You need to replace the fan housing. The fan housing in the DW735 is in two parts that fit together. The flanges on the housing slowly wear away. As the wood chips "polish" as they wear the plastic away, it is not really noticeable. So,
take off both parts of the fan housing (unscrew it from the motor) and you will see a worn area just down from the circular hole for the exhaust.
It doesn't cost too much for a new housing. But it does make a difference.
gary peterson
same here...replace the impeller in the housing(pita with those clips) and should work fine
John Truffa
I've ordered a new fan housing. Hopefully that will fix it.
Bob
Bob
The replacement fan housing solves the problem, you can save some cash as well by ordering from www.ereplacementparts.com, I got one for about half what DeWalt wanted and less shipping cost. Works great.
Bob
John Truffa
Replaced ther fan housing and problem went away. Thanks to all for your help!
