Got a good workout yesterday
Yonak
I unstacked 600 bf of maple, birch and poplar .. stacked 1000 bf of green maple, ash and persimmon in its place and re-stacked the dry 600 bf on top of it. This will give me a good chance to test out the passive solar kiln setup I installed last fall. Since the ash was cut at 8/4 and some of the maple cut at 6/4, it will probably be a year before I can judge the function of the passive kiln.
Re: Got a good workout yesterday
And you didn't even have to buy a gym membership!
Re: Was that a WOOD gloat?
Bob Entwisle in NJ
Sounds like a nice stash of wood
Bob in NJ
Larry in nw ohio
Yonak Where did you say you live? That is going to make some beautiful somethings. Can`t wait for your pictures of what you make out of it, there will be pictures? Larry
Yonak
Larry, I live in west Georgia. The trees were downed in Atlanta. (Seems kind of backwards, doesn't it ?)
The maple and ash are for my business, but the persimmon is my personal stash. I've never worked persimmon before, but I understand it's quite dense. It was historically used for bobbins, pool sticks and golf club heads, etc. I know, for sure, it's heavy, especially green. I put it on the bottom of the stack so I didn't have to lift it so high.
My sawyer told me it was holly white when he cut it, but turned a butter yellow after a short period of surface oxidation. It reminds me of pecan or, maybe, sassafras in the look of the grain. I'll be sure to post a photo whenever I make something with it. It will be a while.
What is a passive solar kiln?
Keith Newton
Did you find plans somewhere, or are you winging it?
I'm just wondering if it would be a bad idea to put green wood in with dryer wood, without good circulation / ventilation.
I'm winging it
Yonak
I'm calling it a "kiln" but it's really a drying assist system. Whereas a true kiln is a highly controlled, closed environment which will dry wood in a short period of time, this is in my lumber building which is all open inside.
I have always used wood that I air dry and I'm counting on this to do two things : maybe dry the wood in a little bit shorter period of time, but mainly to prevent dark spots that develop from mildew when the wood is still really green.
The whole point is to slowly circulate air that has been warmed in a chamber beneath windows in the roof to the bottom of the stack and let it rise through the stack. I don't know if it will work as I hope, but it must be better than stagnant air. I'll also be blowing a fan intermittently on the stack for a few days until the humidity lowers some. I also have a dehumidifier in the building.
As far as green wood being close to dry wood, I can't think of a danger. If anyone knows of one I'd like to know. All the boards are separated by 1" stickers. Certainly no green wood will be touching any dry wood. If anything, the dry wood may even help to dry the green wood to some small extent and I can't imagine the moisture coming off the green lumber could adversely affect the dry wood. It seems like it wouldn't be any worse than a period of high humidity. I'd like to know if I'm wrong about that.
Re: I'm winging it
Keith Newton
"no worse than a period of high humidity"
Maybe a should be changed to an extended period of high humidity.
I don't claim to be an expert at drying lumber, but I have usually kept some along over most of the last 40 years. My concern for your lumber, was that the new green lumber, will likely saturate the air, essentially halting the drying for your other lumber, and yes maybe even taking it back the other way a bit, depending on the volume of space, increase in temperature, and volume of the intake air.
There are probably some experts here that can give you better advice, but, I think I would have chosen to air-dry the new lumber a bit, before combining the two.
You can find a good bit of info over on the woodweb.com site about solar kilns, and perhaps in the archives here too.
I know how much work it is to stack and sticker green lumber, so don't do it without getting more input than mine. They say we learn from our mistakes, but inn not so sur about that. I ought to be a genius by now, if it were.
puzzled
Bill Tindall
Why didn't you stack this green wood outside and let the breezes blow through it? The danger of mold is gone as soon as the surface of the lumber becomes dry. To accomplish this drying you need to move air and the air doesn't need to be hot or even warm. On sensitive species like maple and pine a spray of fungicide would have been a good prevention, but lots of air is just as good.
While the green wood will not damage the drier wood, it certainly will prevent the dry wood from getting any drier. Presuming your "kiln" works, leaving the dry wood in it to dry more would have been a good idea. Leaving the green wood outside in the breezes would also have been a good idea. I had hoped to attach a picture of a saw mill near Corbin KY with 10 million bdft of lumber drying in the breezes but I can't find it.
Now that it is nearly summer, once the surface is dry, the challenge is keeping the thicker lumber from drying too fast.
Re: puzzled
Yonak
Thanks, Bill. It's all a learning experience. If I don't have good luck with this batch, next time I may stack it outside to air dry some before I stack it inside, if I'm up to all the re-stacking. Do you cover it when outside for this short period ? Thanks for the advice.
pile covers
Bill Tindall
Covering a pile outside is important. Cover should extend over the ends and edges so water does not drip on pile.
Yes and No
I learned from an old lumberman to lay the wet boards out in the sun after cutting, flipping them every couple of hours. This is to dry the surface and impede the formation of mold and sticker-stain.
Then seal the ends very well (he used smoking-hot paraffin) and stack with at least 3/4 sticks. If you do the first stage outside, cover with plastic and a good tarp that extend several feet all around and is then staked down.
Then fagedaboudit for about a year or so depending on thickness. I usually cut 5/4 and 9/4 so I don't bother it for a year and a half, then bring it inside, restack and sticker and wait 'til the meter matches the studs.
