We value your privacy.
Howdy all I have the insulation done in the new shop and now it is time for the Sheetrock and finishing. I am thinking of using the 12ft wide rolled vinyl with hard board underneath it.
So my questions is, when I glue it down do I need to cover the entire floor or just the edges and seems? I am going with the cheapest stuff I understand it is thin so will the hardboard be enough under it if it is flat and level?
Don't think I'd use roll goods on a floor that needs to take the abuse of sharp tools and heavy machinery. It'll get tares or rips and you wind up with a mess and perhaps a dangerous trip hazard. If you want vinyl, lay the commercial solid vinyl tile. Very tough, but easy to replace.
Good day Michael When I did my shop I put 1/2"ply down over the subfloor and then I painted it some kind of brown,I not sure what it was, do they make epoxy brown for floors. Sorry I don`t know much about paint, I hate doing it. I told the guy at Lowes and that is what he suggested. It`s holding up, but of course I put old carpeting down when we refloored the house. It works good as long as you do n ot have to move things. It sure helps standing. Good luck with whatever you do. Larry
Hey Mike, I am almost at the same stage you are (I am waiting for electrical inspection before closing up the walls).
My shop occupies part of the basement. As the rest of the basement is receiving hardwood, I am leaning towards putting down 3/4" plywood over my subfloor and jsut sealing it with some poly to help clean-up. Reason for this is that I hate transitions and want to keep all flooring at the same height but can't really justify the expense of hardwood flooring in a workshop...
so I will have concrete slab, topped by 1" XPS foam board taped and sealed, 3/4" OSB as a subfloor and 3/4" ply as flooring.
At least that is the current plan. I will follow your thread to see if any better ideas crop up
To me, hard board is MDF or equivalent, which I wouldn't recommend for a subfloor. If you use only one thickness of it, it will sag between joists; or, if you lay it on concrete, it will swell with the moisture that comes through the 'crete. I guess I'd want to know more about the floor structure and/or any other sub-flooring you plan to use in conjunction with the hard board.
As for laying roll vinyl, I would want a continuous bond, otherwise you'll have air pockets and areas that don't lay flat. I'd also take Mark's comments into consideration, regarding using solid tiles instead of the cheap roll stuff.
I have a 3/4 T&G OSB sub-floor that is flat and level already I was talking the brown stuff they make peg board from. I was thinking the roll flooring would be the cheapest to put down. I was not really worried about what it looked like. I guess I could go with a cheap laminate hard wood that I find on clearness someplace. I will look at the industrial tile and see what the cost is.
Sometimes glued down the make a smooth surface got sheet goods to sit on. OK for a kitchen; not so hot for a shop floor that will carry heavier point loads like table saws, planers, etc.
Mike,
T&G OSB in okay as a subfloor, but I'd suggest a layer of 1/2" CDX ply with thinset in the joints, then the vinyl on the surface.
I would be concerned about CDX plywood. The faces are not particularly smooth and there are often voids in the inner plies.
If you decide not use the Masonite, you want to use Underlayment grade plywood. The face ply is plugged and sanded and the inner ply is also filled so as not to have internal voids on the face side.
If you use vinyl over it I think you want it glued down to prevent it creating a "bow wave" ahead of casters if you try to roll heavy stuff around.
Might look into "vinyl plank flooring" Not sure if it is a continuous glue down or not but might make a nice floor if you can get some on clearance.
Not sure I would want laminate flooring. I have been buying houses at foreclosure lately and have seen a LOT of shabby looking laminate. The cheap stuff sure does not hold up well. We have decided laminate flooring causes foreclosures.
