I've run into two interesting products recently
while building sets for the playhouse.
The first is a product called "Hushboard" http://www.gp.com/build/product.aspx?pid=1071
I used it while building platforms. One of the challenges in building platforms is to make sure you don't hear the people walking on the platforms. You want to hear the actors saying their lines as opposed to anything else. Previously we have been "frugal" and tacked carpet strips between the "joists" of the platforms. The "Hushboard" comes in 4 x 8 sheets and can be placed between the 2 x 4s and the plywood skin of the platforms. It has a STC rating that is fairly high. Which means it could be applied as a skin on stud walls under the drywall (or whatever). You can use it on ceilings and floors. So - for those who have to have sound deadening between their shop space (or dust collection) and whatever else - I offer "Hushboard" as a suggestion.
I put some Hushboard on the stud walls between the dance studio and the light booth. It definitely minimizes the "pitter patter" of the dancers feet.
The other product is something called a "Leg-a-matic" http://www.theatricalhardware.com/Leg-a-Matic.html
This is an aluminum bracket (about 1/4" thick or so) that fits in the corners of your 2 x 4s. You lag bolt them to the 2 x 4s. They add a bit of rack stability and give you an easy way to change the height of a platform. One of the challenges in making platforms for the theatre is that every director wants different heights for the platforms. After a while the 2 x 4s start to look like Swiss cheese with all of the screw holes. If you use carriage bolts, the holes usually wallow out after a while. The "Leg-a-matic" allows you to cut the 2 x 4s to length and quickly change the platform height. I've put six on each platform. If the height is ~18" or less, you don't really need rails between the legs. If the height is greater than 18", diagonal or side rails are recommended.
They run about $6.50 each. I don't know if they would be of much use outside of a theatre or playhouse. After all, how often would you need to vary the height of a table or platform? I will say that the platforms that I built using these are a lot more secure feeling than platforms that I've built using screws or carriage bolts.
