Benchtop Mortising Machine
Lynn Reedy
Good morning from Soddy Daisy Tenn.,
I am in the process of selecting a new benchtop mortising machine.
I have looked at a jet and powermatic machine and like both. There is about $130
difference in these two machines. My question is, has anybody had any experiences,
good or bad, with these two machines. Also is there a better one out there that I have
not talked about here?
Thanks for the help
Re: Benchtop Mortising Machine
George Colonel's Workshop-Havertown PA
Lynn,
I've used the Jet, and Delta machines. They al work fine. I bought a Shop Fox which has a greater capacity and bigger motor.Dual columns also. Use a cross slide vise for stock transport and hold-down.
George
Nick Tuzzolino
I've used the Jet for at least 5 years and it has done everything I expected it to.
The real secret to any of these bench tops ( or any mortiser) is to have the chisels very sharp...
Dave Bair, Eaton Rapids, MI
I've had my JET for about 8 years. I do a lot of Arts and Crafts and the JET has done everything I needed done with only one failure; I broke the drill for the 1/4" chisel. It's replacement has been fine.
Hi Lynn,
I've had a JET-JBM-5 for a bunch of years (see my review under the Badger Pond Articles Section here on WC). It's served me well for what I need, with the caveat that I routinely fine-tune mortices with bench chisels. Speaking of chisels, I still use the original JET chisel set that I got with the machine. I have had them rehoned several times over the past decade, and they do an OK job, again that I do a bit of chisel work anyway. Keep in mind also, that the JET that I have is limited to a max chisel size of 1/2" while other, more powerful machines take up to 3/4" chisels. If I have a larger mortice to cut, I simply make two passes.
I modified my machine by putting on a 2" riser block as I wanted to be able to work with thicker stock. I've also used the cross-slide vice I have for my drill press.
Robin Corell in Atascadero CA
I know you asked about bench top machines but if you have room for it I would go with a foot operted floor machine. The biggest draw back to the floor machines is that if you want one with a small foot print you are pretty much relegated to the vintage market. I have a brackett mortice machine that is from the 1920's or just a bit earlier and it has never been restored, but it was in plug and play condition. Mine is very similar in design and size to contemporary benchtop machines. Wallace made a foot operated machine that I think is probably the highest in quallity with the smallest foot print.
I am lucky in that my machine will accept jet chisels with a slightly modified collet. Many of the older machines require a longer chisel/drill combo which are still available, but at about 4x the cost of the jet tooling
By the way the jet tooling is very high quality. Jet uses Fitch drills and chisels which are made in Austria. Like all mortice chisels they do require that you hone them before using for the first time. from the factory they will look sharp but they should be honed and polished or you wll have to use more force and not get as clean of a mortice.
John in NM
I too have been using a Jet JBM-5 for years, mostly cutting 1/2" and 9/16" mortises. I believe I may be getting close to wearing out the motor after several hundred of those cuts. For routine furniture work, I can't see wearing it out.
The one thing I don't much care for is the little gas piston return - those things are notorious for losing their gas charge in short order, and continual (every year or two) replacement would be impractical.
mdclor
Yeah, my gas piston is pretty much shot as well. Other than that, it is an okay machine. I would have loved to have gotten a Powermatic floor model, but I couldn't justify it. :(
Ron Jones
+1 on the shop fox
Alan in Little Washington (NC)
I had the older style Delta, sold it when I won a Shop Fox. The Delta never moved smoothly despite careful adjustment of the gibs and good lubrication of the ways. As George said, the Shop Fox has greater capacity and has twin columns. It moves up and down effortlessly, much easier than my Delta. I also added a modified cross-slide vise.
The negatives of the Shop Fox- motor turns at 3450 unlike most mortisers which run at 1725 rpm. If you look at drill charts the slower speed matches more closely to the proper rpm for these bits- I haven't really experienced it but overheating of the bits/chisels can result. The SF only came with one 1/2" bit so I bought a set of the much recommended chisel bits from Lee Valley. The shank on these bits is shorter than the SF bits. I don't know if Lee Valley's bits are too short or SF's are long, but there wasn't enough shank for the chuck to get a good grip on the smaller LV bits. They kept coming loose. I ground off about 3/8" from the bottom of the mortiser head casting so the bits insert farther where the chuck grips them securely.
