Sliding glass door problem
Ed O'Neill
I recently started to have trouble with my sliding glass door. Until recently when it became difficult to close, a little silicone spray solved the problem. I cleaned the track and applied silicone but now the door resists and racks and is difficult to completely close. This door has two screws at the base on both sides. I'm hoping someone can advise me as to the best way to adust the door. Thanks for any help you can provide. Ed
Re: Sliding glass door problem
Larry in nw ohio
Ed The two screws are for to raise and lower the door. Try turning them and figure which way they go to raise it, and turn them a little till you can get it to move easier. Good Luck. Larry
Pat Evans
The two screws raise or lower the door relative to the rollers in the bottom. If it's like mine, the rail that the rollers rides on may have worn down to where the bottom of the door is dragging. Raising the door may help. However, you should check the rollers. The bearings may have failed. My track had worn so badly that the track was mushroomed over and the rollers were binding on it. I had to file the track back into usable shape.
John Veerkamp
The rollers are also replaceable. Lift the door out and remove one of the rollers and take it to your home center/hardware store. Pretty simple if the track is still good.
Keith Newton
Over the years, the grit on the track does a number on the rollers, and they may need lubrication too. If raising the door with the adjustment screws doesn't work, I would take it out, so you can see the bottom.
To take it out, slide it to the middle, then grip both sides, lift it high into the top rail, then swing the bottom over the back flange into the room. It has been a while since I had to fool with one, but it seems like they tend to hang up, if the rollers are down much.
I read the above responses and they accumulate to excellent advice. As I read them I would say to myself "Yeah, but" and the next person would cover the but.
On the ones I have you have to take the active door out to the exterior which means I have to remove the exterior fixed panel first. These panels are heavy and you might want to get an assistant for this. Careful with those fingers and toes.
I find that tightening the screws raises that edge of the door. This is the screw back inside the hole in the edge, not the big Phillip's ones that hold the frame together. If you watch, lifting one edge tilts the door in the opening so you need to adjust both sides to get them parallel to the jambs and the other panel in the center.
Before you struggle with removing the door, If you have an air compressor you might try blowing out the track and under the bottom of the door To see if there is an accumulation of crud under the door. Sometimes you can blow them out and raise them slightly and they go back to work.
Ed O'Neill
Thanks guys for the info. I'll try the remedies on Monday and post the results. Thanks again. ED
Keith Newton
Ed, if you find that you need to replace the roller mechanism, I think you can find about three types on amazon, if you can't find them locally.
Bob Entwisle in NJ
Hi Ed,
I have ordered rollers and parts for our aging patio slider from both of the below links.
I've since seen a minor selection of replacement rollers and such at the orange borg too.
http://www.glassdistributorsinc.com/door-hardware/patio-door-hardware.htm
http://www.swisco.com/cl/Patio-Sliding-Glass-Door-Replacement-Hardware
I was amazed at what 5 bucks in parts and a 1/2 hour of my time did for the operation of the door. Like new!
Bob in NJ (who is too stubborn and cheap to simply replace the old sliding door)
Ed O'Neill
Hey Guys, I want to thank all of you who responded to my post with such great advice. Took the door out and got lucky. Each corner had a dual wheel setup with screw adjustments on the corners. Found the most forward set of rollers were gunked up and the leading wheel was frozen. Cleaned the entire bottom of the door, freed up the frozen wheel , used silicon spray on the wheels and track and reinstalled the door. The door slides like its on ice. Wife is happy and therefore i'm happy and it was an easy job. Again thank you. Ed
