OT Satellite internet
John Veerkamp
I'm almost desperate enough to try satellite for internet. I cannot get cable, the air cards don't work here so my only option is satellite. From what I find there are Wild Blue, HughesNet, and Dish. There may be others, but this is a start. For those with any experience with any of these, what would you recommend and what to avoid? Any pitfalls or gottchas?
I'm really tired of 40 kbs max dial-up
Thanks,
John
Re: OT Satellite internet
Yonak
John, you may be limited to a choice of two. Last time I checked, Dish internet is the same as one of those others, but I can't remember which.
The main issue with Hughesnet is that if you go over a certain threshold of usage for a 24 hour period, they punish you by putting you in a level of service that just crawls and is even worse than dial-up, for the next 24 hours. It's incredibly inconvenient because they don't warn you (although you can check your usage proactively), and they don't tell you when they've done it.
Howard Norman
John, I have had HughesNet for about five years. It is better than dialup but no where near as good as cable. Both HN and Wild Blue have what they call "Fair Access Policies". That is a system where if you download more than a predetermined amount they throttle your access way back. In the HN case it used to be that you were cut back for 24 hours and in the WB case, I am told, you were cut back for a much longer period of time. HN has recently changed their policies so that it is not the big issue that it once was. It still is an issue but less of an issue than it was. Don't expect downloads of streaming video from any of the satellite companies.
Thomas S Stockton
John
We have Hughes net, speed is OK can be slow at peak times. The worst part is their fair access policy which limits how much you can download in a day. If you don't have teenagers doing youtube and trying to download or stream music it won't cause much of a problem. Weather can affect it at times but it takes pretty extreme rain or snow to do that, the biggest problem we have is snow on the dish you have to go out and sweep it off. As far as expense it is pretty expensive for what you get although in certain areas the price is subsidized.
The biggest difference I saw between hughes net and wildblue was how they did the fair access policy. wildblue gives you so much for month and then slows you down for a month if you go over and no unlimited download period. Hughesnet does it by 24 hour periods and also has an unlimited download period at night, you also get a free token every month to get out downloading to much plus you can buy more for $12 or so.
We also had no choice so it is way better than dial up, but the phone company is installing some sort of booster at the top of our driveway to supply high speed internet and tv.
I thought that dish just resold hughesnet but it would be worth seeing if that were true.
Tom
Kneale Brownson
Kneale Brownson
I just went with a Verizon hot spot WiFi device. It'll serve up to five computers in the same location. Works a lot better than the aircard I had before.
Wanna buy a dish?
I was on Hughesnet for three years before I was able to get a DSL line. It was adequate but not great, but miles better than dialup. I still have the dish on my roof, as well as a couple satellite modems. You can have them for free and save a big chunk of the initial installation charge, which used to be around $600.
I don't know about the Verizon hot spot technology that Kneale mentioned, but it sounds like it might be worth investigating.
Re: OT  Satellite internet *LINK*
Paul Cates - Henderson, KY
Is fixed-point wireless an option where you live? I've had it for 2 months and am satisfied. I'd rate it a notch below DSL and cable. Search at the link below, but if your zip code doesn't return any results (mine didn't), zoom in on the lower map and see if there's a provider close to you.
Find a WISP
I can sell you Wild Blue stuff cheap
Bill Tindall
email me. We got Verizon 4G installed to our area with a pre-signup special that was hard to beat leaving me with dish and modem of no use.
Look to see that Wild Blue got their new satellite up which will give them added capacity. The previous attempt crashed and burned. With the new satellite you will see a great improvement over dial up. But without the new capacity it was getting crowded at times and slow. The over usage penalty for Wild Blue is much less onerous than Hughes.
John Veerkamp
We have Verizon phones which work fine at home. We signed up for their WiFi hotspot. Didn't have a strong enough signal. They refunded our money.
Next!
Are you way out in the middle of nowhere?
Keith Newton
After reading these post, made me realize how lucky I am. Having DSL here in town isn't a big deal. But, for about 5 years, we have had DSL down at the cabin, which is in the least inhabited portion of the least populated county of the state.
Then last Summer, I came out of the woods upon a couple installing fiber-optic cable right alongside the copper underground lines. I was floored when they told me what they were doing.
We all got a good laugh, when I told them, the last phone in the house we were standing in front of, was a wooden box hanging on the wall, with a hand crank on the side. You had to talk into a cone sticking out the front, and hold the corded cone to your ear. Nobody had numbers, we just told Mrs Jewel who we wanted to speak with.
jimabp
Sorry forgot to load the text
I have Verizon and a Droid phone. Tried the hot spot for a long time but it always dropped me after a short time. It would reconnect and usually stayed on as long as needed.
I finally got disgusted and am now connecting thru the tethered phone (USB) using PdaNet which is faster than the hot spot . I have to pay $30 per month for 2 gigabytes.
Re: Are you way out in the middle of nowhere?
John Veerkamp
Not totally in the middle of nowhere. We're just 25 miles south of the Kansas City metro area, but we are in the middle of farm country. For our dial up the nearest repeater is 4 miles away and they have no current plans to upgrade us over twisted pair copper. No cable here, houses are too few and far between to make it profitable. Ironically we are just 3 miles from US 71 Highway, but all of the cell towers are aimed to provide coverage along the hiway, not to the rural residents.
Larry in nw ohio
Someplace close to Belton or Raymore? Larry
John Veerkamp
South of Harrisonville.
40 KB/sec  dial-up
Dave Bair, Eaton Rapids, MI
My dial-up averages about 6 KB/s and maxes at about 11. I'd love to know your dial-provider!
Re: 40 KB/sec  dial-up
John Veerkamp
Our provider is our local telephone company Fairpoint Communications. They are the only game in town, In Missouri there is no competition allowed for land line providers.
