Bowling Alley Wood
Bowling Alley Wood
Bowling Alley Wood
karl skutski
Don't ask why, but I now am the proud owner of a 10-foot section of a used bowling lane. It is 2 inches thick, pure maple. The lane, as I discovered, is actually made up of 1.1" strips of 2"-inch maple, with some type of gunk between the strips and something else that holds the boards together. I also discovered that when removed from the alley, the lane tends to curl up.
I think it would make a great workbench surface, but I am unsure how to cut it. I don't how the strips are joined, and what kind of saw I should use to make horizontal or vertical cuts. Does anyone know how the maple strips are joined? Also, what do I need to do to flatten out the curl?
Re: Bowling Alley Wood
Dave Dircksen
I bought one a couple years ago, each strip is nailed. Mine had angle iron screwed to the bottom side. That keeps it flat.
Joanne in Point Pleasant, PA
I have a piece waiting to be made into a bench, too. I think the strips are nailed together and there is a piece of angle iron, like Dave's. I bought a few junk blades to use to cut it with the circular saw when I am ready.
karl skutski
Thanks, Dave. I want to cut it lengthwise. Guess that means I will be cutting through nails. What kind of blade do you recommend? I was able to split the strips apart with some wedges, but not sure if I could split the whole length, so I assume I will need to cut through nails.
karl skutski
Thanks, Joanne. Mine didn't come with an angle iron. I want to cut it lengthwise and also take a foot off it. Any idea what blades I would use on my circular saw?
Cheap blades. I would use a circular saw (with a 7 1/4" blade or so). Probably something with 24 teeth to 40 teeth. This would give you a reasonable end finish. I would buy a carbide tipped blade as opposed to just a steel blade. I would use a guide to make sure that your cut is square.
If you lose a couple of teeth on a cheap blade, it doesn't hurt as much as when you lose them on a more expensive blade. You could be lucky and not lose any teeth.
Re: Bowling Alley Wood - Hardened nails
Stuart Johnson
I seem to remember the problem is not just that there are a lot of nails but that they are hardened. Will a regular, cheap or expensive, blade cut them?
Scott in Montana
I would certainly get a metal scanning wand and see what I was in for.
I offered to help a friend cut a section of bowling alley to fit in his breakfast nook. Not only were the nails hardened... they were plentiful. As I remember there was a nail every six inches or so.
All things considered, it would have been easier and cheaper glue up a new section. We went through at least a half dozen cheap blades.
Hope your project goes smoother.
Scott in Montana
Howard Acheson
There are circular saw blade made for cutting flooring that that contains nails.
Re: Here's one
Dick Coers
There's a lot of difference between nails and hardened nails. If they are the hardened nails mentioned earlier, I doubt if anything with teeth is going to cut them. I built my garage with pole barn, ring shank hardened nails since I was using recycled doug fir. Common nails would bend so easily nailing, but if the pole barn nails went badly, they had to be broken off. Incredibly hard! Another thought, I can't imagine nailing hard maple. That would be like nailing concrete, and I suspect the nails are like concrete nails. Good luck!
kskutski
Good advice. Will do it! Thanks.
kskutski
Ugh! Thanks for the warning. Useful info.
Re: Here's one
kskutski
Thanks, Howard. Sounds like I'm in for quite a bit of work. And the darn thing is HEAVY!!!
Re: Here's one
kskutski
Thanks! Sounds like I am going to need it on this project.
Re: Here's one
Bill White
I used alley for my bench. Nailed with spiral shank hardened nails. Was a bear to cut, but the result was worth the effort. I added angle iron braces to the bottom for stability.
You'll be happy with the bench.
Bill
