ADVERTISE HERE - FREE TRIAL
OT electrical questions
DouginDenver
A couple years ago I had a larger main box installed when I added central AC to my house. I just happened to notice the other day that when they did that they put two of my upstairs cirucuits on a two-pole breaker - the kind that looks like two breakers glued together with a little metal pin between the switches so you cannot flip just one side. That's not right is it? What does it take to trip a breaker like that if each "half" is labelled 15 amp? Aren't two pole breakers for 240V circuits?
Re: OT electrical questions
Charlie Lenz
Perhaps the 240V circuit is for your central air, and they moved the other 120V circuits. That would be my best guess. Did they mark it on the panel door ?
Jason Roehl in Lafayette, IN
As Charlie said, it's possible they moved some circuits around.
However, even if there are two 120V circuits on one two-pole breaker, it's not a problem. An amperage greater than the labeled rating on either leg will trip that breaker, with the bonding strap also killing the other leg. So if it's a 20A, 2-pole breaker used for two 120V circuits, then a 21A load on one of those circuits will kill both, even if there's no load on the second.
It's one way to reduce the total wiring on some circuits. For instance, your workbench could have receptacles every 12", with consecutive receptacles on different circuits. (Say there's 6 of them--all the odd numbered would be on one leg, and all the evens on the other). If they're all wired to the same 2-pole breaker, you could run 4 wires to all 6 receptacles--two hots, a neutral and a ground. The hots would power every other receptacle, but the ground and neutral would be shared. To do the same with two separate 120V, single-pole breakers, you would have to run 6 wires--a hot, neutral and ground to each receptacle. That would mean, for example, two runs of 12/2 w/ground vs. one run of 12/3 w/ground, which would be cheaper.
Jason
John in NM
No reason it wouldn't work really, though if you tripped the breaker there would be the nuisance of two dead circuits rather than one. I can't quite figure out why the electrician would bother doing this, the only reason to use a ganged breaker on two 120V circuits is when they share the common. On existing circuits, they would have their own commons, so there would be no reason to use the ganged breaker as opposed to two singles. Are you sure it really isn't a 240V circuit?
Larry in nw ohio
As Charlie said the AC may be on that or maybe some other 240volt circuit. There is no reson to connect the two together without it being a 240. Larry
Bill Howatt
No reason to connect but maybe they ran out of singles.
I did use a double where I could have used 2 singles which was where 2 circuits shared a common switch box. If I need to work in the box it kills the power on both circuits.
Bill
Mark Nowicki
Double breakers are used when a three wire cable ( two hot and one neutral) is connected to the same receptacle.
This provides two 15 amp circuits so it is possible to use , for example, a toaster and a mixer at the same time.
The double breaker ensures that the entire circuit shuts down, so half the receptacle does not remain live.
In Canada we call it a "counter plug" circuit because at least one is required by code, usually in the kitchen.
Mark
Are the breakers labeled? If Charlie's right that it may be your air conditioning but it's labeled for upstairs fixture circuits, you could have a problem if you ever have to cut power to anything in an emergency. Might be worthwhile testing and confirming the labeling.
DouginDenver
I'm sure they are the upstairs circuits. The label deteriorated so I was "mapping" all the circuits to make a new label. The AC is on ganged 30 amp breakers.
DouginDenver
What is used then for a 220 volt cirucuit - like an oven where you have to hot leads but on the same circuit? Also a doube breaker?
Jason Explained it well. And, as Mark mentioned, the most common use I can think of for this is to wire receptacles in the kitchen, where the outlets are closer together and more numerous than most other areas of the house and here you would want two circuits. By using a 240 volt or "common trip" breaker you can run a single piece of 3 conductor with ground to the first outlet and then branch out to two different circuits rather than running two pieces of two conductor with ground. It would work well for bedroom circuits also as it would save money on the "home runs". If this is what you have I suspect it was that way before the panel was replaced and you had not noticed.
Mark Nowicki
A qualified yes. In my case (Sylvania panel) both 220 Volt circuits and Counter plug type circuits (2 times 110 Volt) use a double breaker.
I am not familiar with other manufacturers nor am I an electrician.
Mark
Galen Vetterick
The dual breaker does not happen to be a dual AFCI breaker? Newer code calls for an arc fault breaker in bedrooms as one area of coverage. If the old wiring was not changed they can use the dual type as it allows sharing a common neutral to the two rooms covered.
Just a thought.
Bill Howatt
Any local considerations aside, for some time now, the split receptacle is not a kitchen requirement in Canada anymore it has been superseded by the requirement of GFI protected receptacle if it is within 1 metre of the sink. Because GFI's are difficult with a split duplex receptacle the standard is a 20A circuit.
Bill
Jason Waters
Barry,
I have seen it done to save wire, as you suggest. particularly when the garage has the main panel and they run all the way over to the other end, usually a bedroom. They'll terminate it in a switch box, and feed the various circuits and lights from there.
A friend of mine asked me to help him as he had trouble with his ceiling fan. Turns out the receptacles all had the top 1/2 switched on one leg, and the bottom constant. However, the electrician forgot to break the tabs apart on the receptacle, and in an odd circumstance of wiring and lamp being involved on the switched circuit, it backfed to the fan 220V. He then said, "that's whay the fan hauled a$$ when I turned it on?" And then it burnt out. I said most likely. After breaking the tab out on the receptacle to prevent the backfeed (it was a bizzarre wiring arrangement), everything was good again. Later, I was discussing that situation with a General contractor and he immediately said he was going to check and see if his electrician did wiring like that as he didn't want the liability of a homeowner accessing 240V in a ceiling fan box while on a ladder(one leg being on one circuit, the other on the second). It's allowed by code, but it doesn't necessarily make it a good idea. For instance, my friend and I had to run a long extension cord into the room to get any power to see to do the work as flipping the one breaker (which is required when you do this) turned off all the circuits in that room. to me, the cost savings doesn't justify doing it.
I am not an electrician, so use any information at your own risk!
That is pretty much my objection to the scheme. I really don't like have 220 in the box, but it is "legal". I also don't like having to turn off two circuits at a time to work on the one. My orderly brain wanted to have each room on its own circuit until an electrician explained to me that its better to break them up so that if you have to turn off one circuit, other things in the room are still live so you can see or plug in a tool. "Organizing" things is not always obvious.
Rick Christopherson
They added the two pole breaker because it is required by code. When they added the new panel, all work had be be updated to current code at that time. That doesn't mean that the whole house had to be brought current, but any aspect related to the load center did.
You have a Multi-Wire Branch Circuit (MWBC), and at the time it was created, code did not require a 2-pole breaker unless it also served 240 volt loads. Code was changed so that all MWBC must use 2-pole breakers regardless whether they serve 240 volt loads or not.
