stymied myself
stymied myself
stymied myself
Gary Smyth
I have need to drill 20 identical holes into the 1/2" plywood back of a shallow cabinet 30" x 48" x 5" along a reference line at a rake of 15 degrees. The entrance point at the back has to be at the same point along that line and have the identical angle so that the pins placed in the hole all appear in a straight line and at identical angles when viewed. I do not have a tilting drill press and the cabinet (absent the doors), while not attached to the wall is too large to work that way anyway. I've tried building a 15 degree wedge, and aiming the drill down that angle but it is not stable and the forstner bit wanders on the test piece. I can't get my mind around what I thought was a simple problem. Is there a jig for this (other than the portalign type guide - thirty dollars for a twenty hole project I'd rather avoid)?
Re: stymied myself
Re: stymied myself
Larry Barrett
How about drill the holes perpendicular into a 2x4, take the 2x4 over to your table saw with the blade at a 15 degree angle, and use the resultant piece, clamped to the back of the cabinet, as a guide.
Re: stymied myself
try a different drill bit
Robin Corell in Atascadero CA
Forstner bits do not work well at an angle when used in a hand drill actually they rarely work well in a hand drill. Try a brad point bit with spurs, it will drill straight and the spurs will cause minimal tear out.
Robin
Re: stymied myself
Re: stymied myself
J Barrett Irby
You don't mention the spacing or diameter . How about a combination of the of methods above? Use a strip of pegboard type Masonite to establish the spacing. Make an angled block as described above and a spur point bit and choose the appropriate holes.
Re: stymied myself
Re: stymied myself
I usually use a brad point bit. The spurs cut in and the center point keeps it on track.
I would make a jig and use a drill press. You can usually wedge up the piece to the correct angle and just slide it along.
Re: stymied myself
That'l work
Re: stymied myself
My solution
Gary Smyth
Block is 2 1/2" x 2" full. After a test, 15 degrees seemed a bit too high an angle and did not look "right" so is now 10 degrees. Reference lines provide the top and bottom entrance point of the guide as well as the the center point vertically. Top is angled square to the 10 degree rake. Metal guide is hardware store 1/2" steel spacers which have a 3/8" ID. I'll be able to drill hundreds of angled holes for 3/8" dowels within very close tolerances without damaging the block itself. In a pinch I can knock out the drill guide and use the 1/2" hole alone for 1/2" dowels. I can use double sided tape or waste wood side "outriggers" to hold the block in position while drilling.
