OT Traveling long distance with Garmin???
I have to go to the airport in Raleigh tomorrow to meet friends and travel on to Oklahoma city to see my son, DIL and new granddaughter. I am near Richmond VA.
I just went to the car and tried to program in the address of the airport. It could not find the address. I have used it extensively around the area but hardly at all on out of state trips. I tried the street address alone and the city and street address and even asked it to hunt for the Airport. (It put up and hour glass and then nothing. As I recall, it will load the NC maps when I go across the state line. Right? Is there anything else to do? (I have printed out the Google map directions so I won't have to fly out of "NO Match found", but would rather have the little electronic copilot tell me when to turn.) It's amazing how dependant we get.
Anyone driven off the edge of the map with one of these things?
Re: OT Traveling long distance with Garmin???
Lee Schierer McKean, PA
Don't worry, the edge of the earth is a long way from where you are and where you are going so you won't fall off.
One more way to try. Go indoors and turn on Garmin. Then tell it to go to a city near your destination. Then look at the map of that city. When you do there should be a set location (SET LOC) tab that appears press it and that will lock your Garmin onto that location. Then do a search for the address or just look for an airport. It should find it with no problem.
When searching for an address you need to get to a screen that asks for a state. Once you enter the state it can find the cities in that state. Otherwise it may not find them because it will look in your current state.
Lee
Jason Waters
They are good. I still go to AAA and get paper maps, at least for now.
However, they generally work fine when you get where you are going. We take ours to NY from FL when we fly up there, no issues.
You shouldn't have a problem finding the airport from the interstate. I'd want it for Oklahoma
Jim DeLaney, Austintown, Ohio
Re: OT ...Garmin???   Use Google
Use Google on your computer to get the actual address of the airport, then plug that address into your Garmin. It'll find it.
I've programmed destinations that are 2500 miles away, and Garmin has found them. Shouldn't be a problem.
You also might try
Dustmaker Mike
the name of the airport. I travel a lot and use my Garmin all over the world and have never had a problem. The only thing I make sure and do is still read the street signs because like last night in Columbus the ramp from I670 to I71 was under construction and I had to detour around following the signs the Garmin didn't figure it out until I got back on a know route.
Re: You also might try
George, Oxford, NC
Try
2400 W. Terminal Blvd, Morrisville, NC 27560
George
Scott Greaves
We take ours with us all the time when we travel, and we pre-program in all the addresses we'll need. If it has a problem finding an address you are looking for, we just pick something else close by to get us in the vicinity.
Scott.
Larry in nw ohio
Barrt It sounds to me like you are not changing the State like someone else said. When you first start to program it`ll ask for the state some where, it`s one of the first screens after you touch "Where To" on your first screen. Good Luck and have a safe trip. Larry
J Barrett Irby
I made it. I just drove into NC and then went to the screen for Air Transit and it found the Raleigh Durham airport. The directions it gave were easier and better than Google maps I had printed out, so I went with that. My friend and I were traveling from different directions and the air got to the airport within about five minutes of each other.
Thanks for the help.
Kneale Brownson
Have you updated the device with the computer?
Kneale Brownson
At least once a year I hook up the Garmin to the computer and do a maps update.
I've gone all over the country and generally gotten directions to any address. Except, of course, it tells me to turn left when I should turn right for 1000 feet to my home.
