Cleaning Thrust Bearings
Doug Reynolds in Seattle
I was cutting some green bowl blanks on my Mini Max 20 and one of the thrust bearings does not spin as freely as I think it should. I seem to remember that I should not use a solvent to clean it as that would degrade the lubricant in the bearing. Also, not to use compressed air for the same reason. I could just use a dry tooth brush and get out the bulk. Any other ideas?
Thanks in advance, Doug
Re: Cleaning Thrust Bearings
George Colonel's Workshop-Havertown PA
Good Afternoon Doug,
I had similar problems on my 14" Jet bandsaw. I installed a ceramic bearing. I use the saw daily and its been installed over two years, with no sign of wear. It doesn't spin, yet no groove. I am a believer, as I never got that kind of life from a regular actory-supplied/auto store replacement.
George
Jim DeLaney, Austintown, Ohio
Re: Agree with Col. George
I have the ceramic guides on my TaiChi 14" saw. I put them on after having good experiences with them as the OEM guides on my Laguna 16. They've worked flawlessly on both saws for about ten years, now.
Larry in nw ohio
Colonel Where did you get a ceramic bearing? Thank You Larry
Jason Waters
If you don't want the ceramic for money reasons or whatever, get the bearing number and order 10 from a place like VXB:
http://www.vxb.com/
I bought all the bearings for my Delta Bandsaw rebuild there. I did spring for the Japanese bearings but bought a pack of 10 of the Chinese ones for the thrust bearings (like $10), in case I get in the situation you describe. I'll see how they do then.
Jason
can somebody explain ceramic bearings?
Re: can somebody explain ceramic bearings?
They're not actually bearings, in this case. All they are is a ceramic disc, the same size as the original bearing was, that replaces it. The back of the blade runs against the ceramic, but the ceramic is so hard that it doesn't show any wear.
I think I got mine (it's been a few years) at Woodworkers' Supply.
Where did I get Them?
Good Afternoon Larry,
Hard to remember, its been so long. I recall going thru a catalog, perhaps Klingspor. I recall paying only $12.00 or there abouts for a pair. I installed one in the top guide assembly. The bottom is still functionng with a standard bearing.
George
Hartville tool had them... *LINK*
John in NM
Bit more expensive now, but still not bad, $20.
Not to be confused with the semi-ceramic and full ceramic ball bearings that VXB sells, which are vastly more expensive and not estimated to survive side loads for long. That was just a guess from VXB's staff, I don't think anyone I know of has spent the $80-$150 to pop one on their saw and find out the hard way :D
http://www.hartvilletool.com/product/811/miscellaneous-bandsaw-accessories
