Table saw top
Table saw top
Table saw top
Lynn Reedy
What is best to put on a table saw top so wood will slide better?
Thanks, Lynn Reedy
Soddy Daisy Tenn.
Re: Table saw top
Re: Table saw top
Larry in nw ohio
Lynn I think a lot of people here just use some kind of car wax. I use Turtle wax just because I had some on hand when I was told about car wax. Larry
Re: Table saw top
Re: Table saw top
John McGaw
I have used good old Johnson's paste wax in the yellow and red can (yes, it still exists) on my TS, jointer, router table, and planer tables. Works fine and lasts for a very long time. I would imagine that almost any hard wax would work just as well though. Briwax comes to mind although it might be harder to buff out manually.
Re: Table saw top
Re: Table saw top
Wayland
I use Johnson's paste wax on all machined cast iron surfaces where sliding is involved, viz., table saw, jointer, planer bed, and bandsaw table. On my mortiser table, where the work is supposed to stay clamped to the table and the table are supposed to move together, I use something called "Bowling Alley Wax," which seems to be less slick and a little stickier (I guess maybe it's to make the bowling balls roll instead of slide). I have two partially used cans that are well over 40 years old. I don't know if this stuff is still sold at all, but it works well.
If the table gets rusty, I sand with 220 grit with a ROS set on the lowest speed and WD-40 on the table, then wipe off with rags prior to application of wax. When I put the disc on the ROS, I mis-orient the holes with the slots in the base so the built in vacuum will not pick up the sludge of rust with WD-40.
Re: Table saw top
Re: Table saw top
If you go for car wax, make sure that it is a car wax WITHOUT silicone.
I usually use Renaissance wax. It is a bit pricier than Johnson's paste, but a little goes a long way. I do use Johnson's paste wax on my lathe bed ways.
Re: Table saw top
Re: Table saw top
Rob Sandow
Don't use car wax, Most car wax contains silicon, which will mess with finishes causing fish-eye. I have always used Butcher's Wax.
Re: Table saw top
Re: Table saw top - wood vs. car wax
Carol
Back in the day when I was teaching woodworking, we ran a little experiment. We ran a piece of masking tape down the middle of one side of a table saw top. Waxed one half with MinWax (same as Johnson's or Trewax for floors) and the other half with Turtle Wax for cars.
Then we put a small piece of wood on one side and attempted to blow it off the table. Good job for the blowhard in class. :) The attempted the other side - same piece of wood, same distance from the edge, same blowhard. The wax for wood proved slipperier every time. The car wax gave a nice shine but was not as slippery.
FWIW. It was fun, and wood wax is in the shop anyway. Might be a fun little thing at a woodworking club meeting.
Needless to say, I use wood wax. I did get a car buffer however. Apply a nice thin coat of wax, let it haze, buff out with the car buffer. Buffer was less than $20 and I use it on furniture all the time.
Re: Table saw top
Re: Table saw top
Jim Dillon
Lynn,
I usually scrub the top with Klingspor abrasive blocks and WD-40, wipe off, then apply a thin coat of Renaissance wax. I also keep the top covered during down times with an old flannel sheet. This seems to help prevent rust from forming especially during those spring times when the shop/table top may be cold compared to the humid much warmer outside air.
Jim
Re: Table saw top
I've been told
that car wax has fine abrasives in it to cut through the oxidation on the paint, so that you don't have to use rubbing/polishing compound every time you wax the car.
That could explain the difference you found, Carol.
I can somewhat feel it in the process of waxing the car - not that I do that nearly frequently enough (and, hey, I can't do it right now; it's raining!).
Furniture paste wax is available at well-stocked hardware stores or any big boxy store, and will last a looong time.
Re: Table saw top
Re: Table saw top
Bob Entwisle in NJ
Johnson's paste wax, two coats, lasts a good year or more. stuff slides, table doesn't rust etc.
I tried one of the fancy sprays, T-9 I think, and I found that it doesn't last as long as plain old paste wax.
If you need to clean a little rust or whatever off, a scotchbrite pad and wd40, then wipe it off and wax it.
Bob in NJ
Re: Table saw top
Re: Table saw top
Jason Waters
I am probably one of the few that use "Topcote", which I get from Lee Valley. One can last me a couple years usually. However, if I am out, I revert to Minwax or Johnson's Paste Wax.
I like the Topcote, but it's real important to clean the table top well, I usually use WD-40 with steel wool or an abrasive pad, and after wiping that off, clean with Acetone (it evaporates quickly), and lastly, apply Topcote. I do the same for wax, but that's me.
the Topcote seems to hold up better in my garage in FL with the humidity. Though I do have a rust spot here or there.
If you wax your table every month, you are probably fine with wax.
Re: Table saw top
Re: Table saw top
Tony - Memphis
Howdy neighbor. I've always used plain old MinWax paste wax. Works great and I can use it for my tools and my furniture. A can lasts me for years. I apply it to the fences too. Not bad for gears, etc.
Tony
Re: Table saw top
"  "  (i.e, ditto on Johnson's)
Re: Table saw top
Nothing
Pat Evans
I just clean my table tops with steel wool every now and then. Works for me.
Re: Table saw top
Re: Table saw top
Lets see, I have used Top Coat, Johnson's, Renaissance, Turtle wax, Minwax, Briewax (don't like the look of the dark finish ones - makes the top look tarnished :>), a couple of other car waxes - all worked well on my Joiner, planer, cabinet saw top and bandsaw. I really haven't had any problems with silicone causing fish eyes as I feel the amount left on the top and possibly transferred to the wood was completely removed during sanding and/or scraping. Maybe I'm just lucky - but I use whatever is handy - really can't say I saw any difference when using the equipment.
Re: Table saw top
Re: Table saw top
Jim Breeden
Talc
Re: Table saw top
Re: Yep
Used that too, as I recall, my first 6" joiner (Grizzly) had talc recommended in the instruction book that came with the machine. Used it for several years - seemed to do ok. However I now have an awful lot of cast iron and bare steel in my shop and the wax seems to work better (as far as friction when feeding wood through the machines), and is somewhat faster to apply. I really never buff out the wax, just wipe it down hard with microfiber rags. Works ok for me.
Re: Table saw top
http://boeshield.com/
