OT: Septic Woes
OT: Septic Woes
OT: Septic Woes
jp
Lots of knowledgable and resourceful folks on this site, so hopefully someone can provide advise. Last spring I noticed that our drainfield was leaching to the surface. Not much, but enough to cast a slight odor if the wind was still and you were right next to it. Skip forward to this past December when the floor drain in the basement backed up after what can be described as a 'high water usage' day. 2-3 showers, 5 or so loads of laundry and dishwashing. Since then it has backed up under similar conditions. We had a guy come out to auger the drain and he didn't even bother since he identified the problem as a drainfield issue based upon the evidence that I provided and that the water in the septic tank was high and just rose when he plunged the vent stack from the tank. I don't doubt that his assessment is accurate. Based upon his advice, I dug a small hole in the drain field with a trench leading off into the woods to relieve the pressure on the system. In effect creating an artesian well. My question is this, though. The field is only leaching from one spot and it is close to the tank itself. What this seems to tell me is that the field is not saturated, but blocked at that spot. If that's the case, why then can't I dig down to the pipe and manually clear the blockage? Perhaps cutting the pipe and clearing any roots or solids. Is there something that I'm missing? Has anyone in the collective attempted or heard of others attempting this? For the record, I have the tank pumped every Presidential election, so it's due, but I thought that I'd wait to determine if such a fix is possible.
Thanks
JP
Re: OT: Septic Woes
Re: OT: Septic Woes
JP,
Your issue is more complex. Your leach field is a tree of perforated 4" pipe with 3 to 5 long branches. If you have a stoppage, a cutter may, but may not, be able to reach it from the main distribution box that is the next point after your processing tank. It (the D-box) should be marked on your septic plan which, if you don't have it, may be on file with your township where they issued the permits and did the inspections. You will, however, need a pro on this.
First step is to pump the process tank. Next you'll find the distribution box (by plan or by shovel). Then a camera probe is inserted into the piping and investigates each branch of the field. They will tell you whether you've got a point clog (easy to fix) or whether your field has gone "sour" (big job =$15K).
Re: OT: Septic Woes
Re: OT: Septic Woes
Lee Schierer McKean, PA
Leach fields don't last forever. When they fail, typically the leakage is from one spot where there is a larger gap in the pipe or where the soil is softer. Detergents and other contaminants such as fats from food. There are lots of regulations now on what you can and can't do to existing septic systems in most communities. There can be large fines for doing unapproved work. Your next step should be to check with your local health department to see what your options are. Getting reported by your neighbors will likely reduce your options.
There are various bacterial agents that you can try to see if they can perk up the action in your system without permits. Their success may vary widely despite the claims on the packages. I used a product called Bio Sure for years and it seemed to do a good job prolonging the life of my system. Two years ago we had a problem similar to yours and the only repair we could legally undertake was a small flow treatment system (which involved burying $15,000 worth of tanks and pipes in the back yard). It had to be permitted by the county, designed by a P.E. and installed by approved contractor. All in all it has been a worth while investment to maintain the value of our home.
Lee
Re: OT: Septic Woes
Re: OT: Septic Woes
jp
Ouch. The guy that came out provided a ball park estimate of 6-8k. He also speculated that since the house was built well before planning and zoning in our area, it is likely undersized. That said, I doubt that there is a plan of the leach field on file. I'll be sure to check, though.
Re: OT: Septic Woes
Re: OT: Septic Woes
Gary Camp, Bend, Oregon
I work with guy that can hydro-jet lines from the d-box, he can also send a tv camera down the lines and look at what is in there. He can trace the head of the camera and pretty much tell you where each line of the system goes. Pumping the tank a couple of times (as soon as it fills up) may by you a bit healing time while you investigate your options. If you have to rebuild your drainfield check out the Infiltrator system, I used that on my drainfield and it was very easy to install. I had to put in 270 feet of drainfield line in soil that you can hardly make water stand on. I'm not sure that anything has ever reached the end of the drainlines even after 3-1/2 years. You've made me curious so I will have to check tonight or tomorrow.
Re: OT: Septic Woes
Re: OT: Septic Woes
John in NM
Man, that price is about right for a complete, new system out here. I paid about $6k in 2005 for a system with two tanks and a lot of trenching. There were also a lot of guys who would have done it for less, but I figured with septic it pays to go with the outfit everyone says is the best. So even with a bit of inflation, that $6k would buy you a new system here, maybe $8k if you hired the guy I did in 2005.
Re: OT: Septic Woes
Cost
If his leach field is clogged, it will have to excavated to a point where it will pass a perk test, then refilled with stone and rebuilt. For a 4 bed/2 bath house, that is likely to translate into 900 cubic yards of toxic soil and fill removal by a licensed removal company. I don't know where JP is located, but in my wood patch he'd be lucky to get by at $20K for that kind of job.
Let's hope he's just got a point blockage.
Re: OT: Septic Woes
Dale Lenz
Re: OT: Septic Woes
Dale Lenz
We just rerouted our leach field and put in new larger pipes, half of barrel looking things, I could of layed down and hid in them. Put in close to 300' 5-7 years ago, 2500 dollars here in Okla. I thought I got took on the price, the back-hole contractor did not want to mess around with someone elses poop, can't blame him, so I paid the price and went on with life.
Re: OT: Septic Woes
Re: OT: Septic Woes
Stuart Johnson
Our county will no longer allow leach fields or repair of existing fields. Our only option was to go with an aerobic system. It works well but would be better if we could change the spray area with hoses in order to use the water where needed.
Re: OT: Septic Woes
Re: OT: Septic Woes
Larry in nw ohio
JP I`m not sure about what I`m about to tell you so I hope other people chime in to be sure. If you do clean out your septic tank, by that I mean emptying it, make sure you pretty well fill it up again with water. When we put one in for my mother years ago, that is what I was told, because if you don`t and you get a bunch of rain it could rise right out of the ground like a submarine doing an emergency surface. I do not know this for sure, but I didn`t take a chance for what little that water would cost as opposed to redoing. GOOD LUCK Larry
Re: OT: Septic Woes
Yeah...
John in NM
Out here they just put another next to it :D
Re: OT: Septic Woes
Re: Yeah...
I have not put one in or dealt with one in years, but when I was building, the counties required the site to have an alternate drainfield site. If the first one failed you installed a second one in the alternate site. There were also cases where there was no alternate site so they just installed stretches between the existing trenches and put the "new" drainfield there.
Many more sophisticated systems have come alone since then. (Read as $$$$$)
Re: OT: Septic Woes
Re: OT: Septic Woes
JP
I've heard the samething. Not going to have the tank pumped just yet, but will do once I determine what course of action to take. Seriously thinking of attempting this myself in the not too distant future. The level of water in the tank has dropped considerably since yesterday as has the seapage. There's an 18" diameter oak tree not 5 feet from the spot. I'm willing to wager that that is where the blockage is if that is indeed the problem. Any advice on doing this would be greatly appreciated. Seems on the surface to be not all that complicated just a lot of shoveling and lifting...not to mention dirty. From what I've read the upper layer of gravel is only 2-3 inches. The probe they used when they came out earlier hit gravel at 18". So dig to uncover a section of the pipe where I expect to find the block, cut out a section to gain access, clean out manually or otherwise, patch pipe, cover in gravel, landscape fabric and dirt. What am I missing?
Re: OT: Septic Woes
Jim DeLaney, Austintown, Ohio
Re: OT: Septic Woes
Hadn't heard that one, but I do know that heavy rains, as they soak in, will also backflow into the leach field drain lines and backfill the septic tanks.
Also, when the leachfield is saturated by rainwater, the septic system is minimally functional.
Re: OT: Septic Woes
Kneale Brownson
Manifold header
Kneale Brownson
Some drainfields do not use a distribution box, but rather a header pipe with Tees leading to each leg of the field.
Re: OT: Septic Woes
Kneale Brownson
Re: OT: Septic Woes
Kneale Brownson
Depends upon the ground and local requirements. Drainfields typicall have a foot of gravel in them with 4" perforated pipe placed about two inches below the top.
Typical pipe material is thin, slip-together design, so if you can uncover a corner, you might be able to pull it apart instead of having to cut it.
As someone else noted, some local authorities take dim views of fiddling with septic systems. Fines can be substantial.
Re: OT: Septic Woes
Re: OT: Septic Woes
Jerry Nicholson
I don't have any useful answers but I feel your pain. When I had my house built in 1962 there apparently no regulations and I had an inadequate leach field in tight soil on the back half of a 5/8 acre lot. I fought septic system problems continuously until about 1990 when I was able to connect to a new sewer line. I had to have my tank pumped yearly and it never popped out of the ground due to rain, as has been suggested here. Of course it filled back up pretty quick. One thing that helped a little bit was running the washing machine water on to the grass during warm weather. My Bermuda grass thought it was great! I suppose that was illegal.
Jerry
Re: OT: Septic Woes
Re: Manifold header
Someone who knows what to look for can sometimes inspect the distribution box and tell if the lines are getting a proper distribution of water. Sometimes the box is poorly installed or gets shifted and most or all of the water goes into one or perhaps two lines. if this is he case, you (or a professional) may be able to reset the box and put the other lines back into service.
Also, hardwood trees in the drain field are not a good idea. Their roots are invasive. The water and the nutrients in it are very attractive to the trees and their roots seek it out. Pines or other less invasive trees may be better, but still not desirable. You may be able to remove and replace the affected section of pipe, but the roots will grow back quickly unless you remove the tree(s).
Re: OT: Septic Woes
Re: OT: Septic Woes, update
jp
Don't mean to imply that ours is any better than anyone else's here, but holy s.
Had the guy come out to pump the tank and evaluate our situation. He said the tank looked good and all the baffles were solid and as far as he could tell, no solids had entered the drain field. He also agreed with the plumbers that had come out and said that we likely only had 75-100 feet of drain field. Additionally, given the age of the system, there is no d-box. We were just about to wrap up when he walked over to where the outlet side of the tank is buried and looked at the ground and said, "you know, I bet that outlet pie is kinked. See how it's settled here?" We dug it up and sure enough, the outlet pipe, which was originally 4" pipe was smashed down so that there was only a 3/4 inch opening to the pipe. Problem located. The pipe was dug up, replaced with schedule 40 PVC, cemented in place, and cleanout installed. That's pretty much where we are right now. We're going to keep an eye on it and see if that does indeed fix the problem.
Thanks to all of you who offered advice and/or commiserated with our problem!
JP
Re: OT: Septic Woes
Bill White
Holy S.
That was the best pun I've seen in a while.
Bill
Re: OT: Septic Woes
Nice!
John in NM
Great to hear about it when someone gets lucky! :D
Also great to have a good contractor who knows his business.
Re: OT: Septic Woes
Al Stokka - Cambridge, Iowa
jp,
How old is your tank sucker guy? Sounds as if he's over 60, cause he knows his sh, er, stuff.
My guy is nearing 75 and I love standing near him while the truck empties the tank just to listen to his stories about other folks' septic tank troubles.
If you guy is 60 or over and has been in the business quite a wile, next time he's at your place ask him about tossing something into the tank after it's cleaned out to "get it going again." The tales I've heard are amazing.
Hope your troubles are over.
Al
Re: OT: Septic Woes
Kneale Brownson
Cow Plops?
Re: OT: Septic Woes
JP
Guy told me that he's 72 and that he'd be around to pump the tank one more time before he was done. He also told me that both 4 and 8 years ago when he came to pump it. After spending well over an hour there this time he told me, "well, John, I've taken enough S from you. I'm leaving"
Re: OT: Septic Woes
jp,
Sounds just like my guy.
He told me that a customer, after having the tank pumped out, wanted a dead hog thrown into the septic tank to get it "working" again. Of couse he obliged, knowing full well that the first flush of a toilet would do as much good. Gotta keep the customer happy!
Love his stories.
Al
