Radial arm saw station ideas?
Charles Jackson III
I am looking for ideas for a radial arm saw station, I would like to build two cabinets and sit the radial arm saw between them, more like a crosscut station.
Charles Jackson III
Re: Radial arm saw station ideas?
Joanne in Point Pleasant, PA
Here's what I came up with. Works great and has lots of cutoff storage area. I built a big cabinet area and then built ribs for the deck that covers the saw and extension areas. That left me room for 4 drawers for more storage. I'm still working on the dust collection hood and getting a better blade, but it is functional now.
Make sure that the area under the saw blade can be removed and renewed as necessary.
That's a good reminder. My main deck is 3/4" plywood, but I put 1/4" hardboard strips in at the 90 and 45 degree cut areas. I figured I wouldn't be very likely to use this thing for fancy angles other than those. But the cart that previously held the saw (that I inherited) had a sheet of hardboard for the entire top area.
Carol
I went a lightly different direction. I had a Sears RAS many years ago and as a crosscut saw, it was not fun to use. I bought one of the original Hitachi SCMS and still have it. Even have a 10" model also. After the RS became an inefficient table to pile stuff on, I sold it to the first guy who saw it. I think he broke speeding laws to get to my shop!
A year or so ago I revisited the idea of a RAS, but for the dedicated purpose of cutting rabbets and dadoes. I bought a 1953 Delta turret style cast iron monster (in weight) 9" RAS. I worked on automating it with a pneumatic cylinder, but was not happy with that. I now have a linear actuator that I need to install.
With that said, my RAS table is 3/4" BB plywood with no cutting slots because of its intended purpose. It is on wheels and has flip up support tables to each side. One of those flip up tables is fastened to the SCMS for extended support for both saws. I did build a cabinet for it which helped bring all the surfaces co-planer with one another and provided for drawer storage beneath. It is still waiting for the drawers. Life intervened. When I got a 6" negative rake dado set for it, it became a very nice, tame, machine to use.
My point is to determine what your use is intended to be and design accordingly. I prefer to use the SCMS for crosscuts. The RAS is my rabbet/dado machine. I have room for both. That may also be a consideration for you.
Charles Jackson III
I have a 9'' DeWalt MMB 23 RAS, I use my RAS for crosscutting and angle work. Have not try dado/tenon work yet?
