200+ woodworking book reviews
OT Ice Maker questions
I have a Kenmore fridge with an ice maker. Sort of old school. The unit is in the freezer compartment and it makes those crescent shaped "cubes". It has slowed down and appears to be making ice at about half the usual rate. Not really keeping up and its clear that it won't be adequate when hot weather comes.
I thought these things ran on a timer and made ice every so many minutes. Any Ideas why it slowed down and how to speed it up? Also, I thought these things had a heat cycle that released the ice. I suspect this one has a failed heating element. It seems to really "fire" the ice out. As if it can barely over come the resistance and then the ice shoots out.
Any ideas?
Re: OT Ice Maker questions
Dick Coers
Some ice makers flex the tray to pop out the ice cubes. Make sure the fill tube is not partially blocked with ice.
john Veerkamp
When my maker did this I eventually traced it to a restriction (calcium build up) in the needle valve that tapped into the water line and supplied water to the ice maker. Replacing the valve fixed the problem. One other possibility, most fridges have a filter for the incoming water. It may be clogged. These filters are sometimes inside and sometimes inline on the back.
Lee Gordon
Lee Gordon
If your ice maker is like the other Kenmore-Whirlpool-Roper models I've seen, it does not work on a timer. There should be a thin metal bar across the front of the unit. It's purpose is to detect how much ice is in the bin. If it cannot move all the way down (in other words, if ice in the bin is piled high enough to prevent it from completing its downward movement) the ice maker stops making cubes until it does. Sometimes, even if the bin is not full, a couple of those half-moon cubes will hang on that bar with one cube on one side of the bar and the attached cube on the other, preventing the bar from moving all the way down. In that case, you just have to clear the ice off the bar and shake the bin to make the ice in it settle, and you should get more ice. If not, your unit may be defective.
Jason Waters
Ice makers are finiky at best. Is this one of the ones that discharges ice through the door?
Sometimes, you might be surprised at how cheap the ice maker unit (the entire unit) is compared to a few parts. Not all of them you can get this way, but it helps. Another thing is that Sears and other places do these fixed cost repairs. It's usally $250 or so, but it includes all parts, and a warranty no matter what the problem is. I know that's not cheap, but those parts add up. I have seen a vegatable drawer be over $100.....
What I do in these situations
Bill Tindall
Even in E. TN we have appliance repair parts stores. When our ice maker, or other appliance, fails I go to the store, describe the symptoms and the nice lady sells me the parts necessary. The whole ice maker unit cost less than $100 that last one I replaced. (I was told to sniff a certain part and if it smelled like fried electronics I needed a new one).
All ours flex the tray to eject the ice. The whole process is on a timer. If the cubes are full sized the fill cycle is functioning properly. Well, actually, if the cubes are full sized the whole unit is functioning properly, in our case.
Re: What I do in these situations
Larry in NW Ohio
Barry How old is your fridge is the ice maker the same age? If both are say maybe years even 6-8 then look at the ice maker and if you can see the bottom of the ice cube tray, where the water is keeped while it is being frozen, and if that tray at the bottom looks kind of like the coating is wearing off, then you need a new maker. That coating is to keep the ice from completely freezing to the bottom, something like a Teflon pan. Another maybe your filter, if you have one. One wat to test the filter is if you have a place to fill a cup of water, take a cup of water and time it on how long it takes to fill your cup. Now take your filter out and take your cup and time how long it takes to fill the cup without your filter in-line. If it does not fill your cup quite as full then you need a new filter, because your filter is dirty. I hope this helped. Larry
Bill Turpin in WNC mountains
Many ice makers have a temp sensor that detects that the freezer is cold enough to make ice. This is usually minus 5° to -10° F. Ice cycle will not start until temp sensor makes contact. Make sure that freezer has not lost some of its cooling ability. Have you cleaned the condenser coil underneath? Is the defrost cycle working properly? Is there good airflow from the freezer into the refrig side? Is your thermostat keeping the box temp the same? Thermostats start failing by allowing temp to rise. None of these will be fixed by a new icemaker. Do you have children(or big children...that is YOU ) that stand with door open deciding what they want to eat?
Re: OK, So I moved the pizza....
As is often the case two or three things changed at one time. I bought a couple of small frozen pizzas and stuck hem in the freezer standing on edge next tot he ice maker. About the same time my son decided to dump the old ice out of the box. That's when we noticed the ice maker was not keeping up or just barely keeping up. It became clear it would not be up to the task when warm weather and Iced tea season arrives. I was wondering if the old ice was disguising the fact that the unit was slow? I knew the little arm had to be free to do its thing. I also knew that there had to be good air circulation. I think my son pushed the pizza boxes all the way back, blocking the air flow. When I moved them, it emptied out some new ice a few minuted later, so we will see if it comes back up to speed.
(At my house, the freezer makes ice and other than that is the place good food goes to die a slow death. In the fridge, I can store a steak for a week or so and then throw it out. The freezer allows me to store it a few months, and then throw it out.)
Larry in NW Ohio
Barry One thing that Bill Turpin said that I also wanted to say, make sure you KEEP your coils clean. I have a little trick that helps keep them clean. Get some filter material, it`s something made by RPS products Best Air, Carbon Filter, it`s about 1/8" thick 16 1/2"X48" and I get some velcro and cut a strip about 2-3" and put velcro on the side of the fridge on the bottom and stick the filter to that and then put some on the front behind the grill so as to filter the air coming in and over the coils, if that is where the coils are. It really keeps the coils cleaner.Larry
Hal
Had the same model atone time which wouldn't eject cubes (crescents). Decided it was the heating element that loosens the cubes. Went to the local Sears store and bought a new unit for about $125 (as I remember). Not difficult to install. Any good woodworker should have no problem (don't ask for the connection between woodworking and installing an icemaker). Worked just fine for several years until I sold the refer. Probably still working. Good luck. Hal
steak
Bill Tindall
steaks can be dry aged for a month. There wouldn't be any steak in our house only a week old that would be thrown out....it would just be getting good to eat.
Re: steak  Bill, questions???
I bought my son some groceries and left them in the kitchen for him to put them away. (It was enough that I bought them and brought them home, I thought he could take the responsibility for putting them away.....?????) He left them sitting on the counter for at least 36 hours, probably closer to 48 and then put them away. Included was a package of steak that he left in the fridge for about another week and then cooked it rare and ate it. He didn't die. Was not even sick. Is this what you would call dry aging?
Can you describe it better?
Joseph Mulherin
We have a side-by-side fridge/freezer...Hotpoint... the icemaker went sour swo I bought one online and it was shipped to the house for $156.21. Installed it myself using their instructionsw in about 10 minutes.
Also changed out the filter located in the upper fridge righthand corner. They should be changed out at least every 6 months....regardless....for optimum operation.
Nah shouldn't hurt, when my wife and I were married 'bout 42 years ago the local grocery stores sold "Dark steaks" that had turned a little brown from setting in the cooler for 1/2 price or less. I always felt these were the best steaks. Most of the old time beef was hung for at least 4 to 6 weeks at about 38 - 40 degree F to tenderize before cutting. Today the grain fed is only hung a week or so. Still makes a better steak. My wife thought the dark steaks were spoiled so wouldn't eat any for several months. I guess she was seeing if I stayed alive. Finally she ate one - after that I had to share. Don't know why but they quit selling the Dark steaks, I would buy everyone I found.
