Trying something new with planting plants
Larry in NW Ohio
I tried something last year when we planted trees and other plants. When we were having a little drought and having some pretty good cracks in the ground and when I would try water them the water would just run in the crack, and I thought what a waste of my time and water. I got to thinking what I could do to hold water around the plants and not let the water go to waste. So I pushed dirt up around the plant to keep the water around the plants so it would soak in somewhat. But didn`t work real well though. So I came up with putting a 6" PVC tile around the plants, flowers and trees. I made them about 8" long so I could push them in the groung some. So I would like the people that work,or anyone else, with plants and trees, what they think about this if it would work OK or if I`m missing something. It seemed to work, but I don`t know what if this may damage the plant somehow? Thank You Larry
Re: Trying something new with planting plants
Tom Dunlap
My Dad taught me a good watering technique. The place where we lived was all sugar sand and didn't hold water.
Take a five or ten gallon bucket. Drill a hole in the bottom...3/16 is a good size.
Place the buckets next to the trees and fill with water. Drip irrigation on the cheap! If its windy tie the bucket handle to the tree or you'll loose the bucket.
Tom
Jim Breeden
Tom - You sure you don't live in New Mexico :D
Tom Dunlap
I learned that from Dad when we lived in Minneapolis!
Jim Breeden
Just wondering. We presently have 40+ MPH winds, w/gusts to 60. Normal this time of year here in New Mexico. :b
I am with Tom on this one. I have used "wee wee" buckets for years. I found that any little piece of debris would stop up the holes in the bottom of the bucket, so I drilled an 1/8" hole on the side down low about a 1/4" up from the bottom. I would water the plant directly and then fill the bucket and let it go. If it took an hour to empty, that was fine. (never took that long)
I have also buried a piece of perforated pipe into the hole with the plant and then set the bucket to drain into the pipe. This put the water in the bottom of the hole.
Never even thought about the wind though.
Chuck Bjorgen
It's probably best not to hill up the soil around trees and shrubs to conserve moisture. A time-honored method is to use a mulch of organic material. In the case of trees and shrubs, wood chips will work nicely. For other garden plants, a mulch of leaves and/or grass clippings will work to keep the soil damp and cool while still allowing rainfall or watering to reach the plant roots. It also prevents weeds from sprouting.
I maintain a couple of compost piles the products of which I regularly add to my garden areas and particularly to any new plantings. We composters call it black gold.
