cut-offs
cut-offs
cut-offs
Pat Evans
Cauls, clamp blocks, spacers, shims, jigs, templates, test cuts, test finishes, etc., etc., etc.
In every cut-off I see a potential use. However, I also rapidly run out of storage space. I usually throw cut-offs under the RAS table and when I can't get any more in there, I cull through them. (My least favorite shop job.)
What's your rational for keeping/throwing out cut-offs?
Re: cut-offs
Re: cut-offs
I can't keep them in stock.
All of my hardwood cut-offs have a potential home - several people heat with wood stoves and burners in our area. Come fall and winter, I can never keep my cut-offs. Everyone wants them.
Spring and summer they go out as fire starters for the burn pile.
Re: cut-offs
Re: cut-offs
Larry in NW Ohio
I do basically the same thing with the garbage cans. I`ll fill maybe two of them stacked fairly neatly and anything after that I sort and throw away. As they say, you can`t keep it all. But if I come across something really nice, I`ll keep that a throw something away that is in one of the cans. Larry
Re: cut-offs
Re: cut-offs
George Colonel's Workshop-Havertown PA
Good Afternoon Pat,
Normally, I keep cutoffs until the present project is completed. Then decide which to save. I save them as long as I can stand it, then reassess. I always reassess maple, cherry, figured oaks, walnut, mahogany, bubinga. Sometimes poplar. Sawdust is unworthy of this level of attention.
Its a reason for celebration when I do finally find a use for those offcuts which I've spent so much time reassessing. They are rare, like a good steak, and tend to justify their reassessment. It takes a special offcut to make that cut. Beyond that, its pretty straightforward. :D
George
Re: cut-offs
ROFL ! . . .
steve mackay
Thats an entire lumber yard to me ! That pile alone would supply me for a couple months ! "Scraps" gotta be "dust" before they get thrown out.
Re: cut-offs
Anything Shorter Than 12"
Goes in Memsahib's kindling buckets. No matter the type. I know I'll never use anything that small.
All else gets sorted into the Shorts Bins by species. Since I made the decision to save for another day, those bins are the first place I go before I start milling new stock for another piece.
Re: cut-offs
Re: Rational ? Whats that ?
Re: cut-offs
Used to save for firewood...
John in NM
Now I end up using them all from making grips and short gunstocks (8.5") A couple times I've bought an 8/4 plank and turned it into 40 odd 3x4 pieces :D
I used up my accumulation of thick off cuts ages ago, been scrounging them from friends shops ever since. 4/4 is still a problem though, most of what I use is 8/4
Re: cut-offs
teak
Jerry Gibbs
A friend asked a marina if they had scrap teak. He was laughed at. When the teak gets too small for anything else, they make plugs out of it.
Re: cut-offs
Just glued up
Charles Yawn
A bunch of my scraps that looked like yours and made a bunch of birdhouses for the neighborhood.
Charles
Re: cut-offs
rationale misspelled
Re: cut-offs
Kindling for others with fire places
Pete in Holland MI
Wood deemed too small for practical extended storage is cut down to kindling size and packaged in boxes. I don't have a fire place or wood stove, so they are carted off to work where I have several friends with fireplaces who love to get my scraps.
If too much wood accumulates, it gets piled up outside, where it will be fuel for my steam tractor in the spring.
Sawdust and green turning noodles head to the firepit in the evening (most woodworking done during the cold winter months) where a little used oil keeps things burning until they are gone by morning. Sometimes , a small squirrel cage blower helps moves things along. I live in a neighborhood, so burning these type of smoky things are not a good option when everybody's windows are open.
Pete
Re: cut-offs
Re: cut-offs
Tom Pilsbury (Chicago)
I look at that pile and I don't see scraps. I see small boxes, bird feeders, earrings and beads, (I also make jewelry), knobs and handles, backer boards, drawer faces and bottoms, trim, and if I ever get around to it inlay strips. That's just off the top of my head. Oh yeah picture frames. Ain't no scraps in my shop!
Re: cut-offs
I agree until I run out of room...
Pat Evans
then they become scrap. :)
Re: cut-offs
Kneale Brownson
Re: cut-offs
Kneale Brownson
Firewood
