OT - HVAC advice needed
When they ducted the auditorium of the playhouse, they put the "registers" or vents in the suspended ceiling. While this is fine for warmer weather, it doesn't work too well in colder weather - it is a LONG way down to the audience.
We can't really put in new ducting - the auditorium seats are on concrete "terraces". The hot air rises and collects near the roof - the lighting catwalk is quite warm with the rising air and the heat from the lights.
Would it be reasonable to put some fans or squirrel cage motors up in the upper area to help the warmer air get down to the audience? Would I even need ducts?
It might be possible to put ducting on the auditorium right side on the other side of the wall - but I don't know if that would be enough circulation.
Here is the main floor plan.
I could use the closet on the right or the triangular shaped piece
