REAL MILK PAINT
On installing stair treads and risers
Bill Tindall
There are several ways to approach this task. This is how I do it.
There are several problems to contend with. With these stairs the treads and risers are captured between two walls, which are never parallel or at perfect right angles to the treads and risers. Hence each tread and riser must be fit to the opening. If the fit is too tight the risers or treads will push the walls or skirt board out and leave a gap in the previous riser or tread installed, so each riser and tread must be fit perfectly and not wedged. In this job the back of the stairs was not accessible so the treads had to be installed bottom to top to maintain access to the back for nailing the riser to the tread.
Step 1 Put a straight edge across the riser part of the stringers to see that the center stringer is either perfectly aligned or slightly inset from the outer stringers. It is a nightmare to fit the treads and risers if the center stringer is out some. In my case I had to mow off 1/8" from the center stringer at each riser, a tedious process with chisel and saber saw.
Step 2 Picture 1
Make a pattern riser and tread from a thin piece of plywood. Put these parts in position on the stringers to see how out of square the situation is at the intersection of skirt board and tread and riser as seen in Picture 1. This picture shows the tools needed. A pattern stringer and tread, a length measuring stick (made from Lee Valley part), drill, 3" trim screws for fastening the tread, construction adhesive to put under each tread to prevent squeaks, and a gauge stick used to consistently mark screw locations.
Step 3 Picture 2
Measure the out of squarness as shown in Picture 2. In this case the tread needs to be 1/16 longer in the front than the back on the right side. It is easy to screw up so a note pad to record this information is handy. Also shown in the picture is the screw location gauge.
Step 4 Picture 3
At this point we are starting with a tread, or riser, that is a bit longer than the opening. With a marking knife and square mark the amount out of square the tread needs to be cut based on the measurement from step 3.
Step 5 Picture 4
Cut the end of the tread at the angle marked in step 4. After a cut or two it will become easy to judge the angle required. For example in this case if the tread needed to be 1/16" out of square I needed to adjust the miter about 1/2 degree. You will have the sharp scribe line to go by. Note I am using my favored 7 1/2" blade. If I was off a bit on the miter setting I could free hand a small correction with this blade.
Step 6 Picture 5
Champher the ends but not all the way to the front edge that shows. Champhering aids the next fitting step.
Step 7 Picture 6
Do a test fit for the right end of the tread by lowering it into position on the stairs. (The tread is purposely too long overall at this step so we are only fitting the right side) If not perfect return to the saw and correct the angle. Now using the slidy stick shown in the first picture measure the length of the tread opening either at the front or back. Repeat steps 1 to 6 to get the left end angle of the tread perfect and the length perfect. By test fitting get the angle right first, with the tread jst a bit too long and then when the angles on each end are perfect make a final cut to length using the miter setting that resulted in a perfect angle for the left end. Yes, this is tedious but necessary to get a perfect fit. Repeat all these steps for the corresponding riser.
Step 8 Picture 7
For this kind of stairs you must start at the bottom step. Install the riser making sure it is at the perfect height to butt what will be the bottom of the tread above it. A brad nailer is handy. Put a bead of construction adhesive on each stringer, butt the tread tight against the riser and screw down the tread. Finally, nail the bottom of the riser to the back of the tread.
Step 9 Picture 8
Install the moldings and you are done.
Re: On installing stair treads and risers
PS
Bill Tindall
After that "little" diversion I can get back to making furniture. I built the house 19 years ago. It really was time to be rid of the temporary construction stairs made from rough cut poplar.
Charlie Lenz
You did a very nice job on the steps. For the carpet runner they make a rod that fits across the runner in the inside corner of the step. It holds the carpet tight.
Jim Breeden
I've have been thinking about replacing the worn carpet on our stairs with oak replacement risers and treads. Lowe's has a kit for doing this. But, looking at the photos, I'm not sure if I want to tackle this project. :b Maybe new carpet is a better idea.
Beautiful job!!
Bruce, a MN Galoot
Nice job Bill! I replaced our carpeted stairs with oak treads and risers a year ago. It's a lot of work. My beloved decided she wanted them done 1-1/2 weeks before Christmas.
Great looking job Bill - bet that took a while. The stairs in my 120 + year old house are carpeted (and going to stay that way :>) ) . I don't think my old knees would hold up to that job!
