Making dust ports
Making dust ports
Making dust ports
Carol Reed, Pahrump, NV
Charlie Lentz seems to be talented in this department, and perhaps there are others as well. I need to make a side collecting dust port for my table saw. It would be wonderful to see and hear the thinking that goes into making this sort of thing. I bought a small metal brake from HF. The instructions are useless to me. How about some idea about how to use that thing? Thanks.
Re: Making dust ports
wooden leg
The last side port dust collector, I had made I went to a heating and cooling shop and had them make a funnel shape the size of the hole of the port and then necked down to the size that would fit in the hose. I found it was easier for me that way. Hope it helps. Dave
Gary Camp, Bend Oregon
Carol I've made all my dust collection stuff from 1/4" plywood. For my contractors saw I made a simple box sloped towards the back with a hole routed in a piece of 3/4 ply the size of my dust collector hose.
glc
Charlie Lenz
Carol, I'm guessing that this is the brake that you bought http://www.harborfreight.com/18-inch-bending-brake-39103.html If so, I can see what you mean about the manual, perhaps this might help you understand how it works. http://www.instructables.com/id/Imporved-Harbor-Freight-metal-bending-brake/ If I didn't have a different style brake, I'd take pics and show you.
Re: Making dust ports ( Gary )
Charlie Lenz
Gary, for giggles I'd like to see the table saw dust hood.
Well no, Charlie, it didn't. It showed me how to 'improve' it. I also looked his copper cap project but that didn't help much either. I have never seen a metal brake operated. I cannot picture how it works in my head. Can you help with that?
Re: Making dust ports *LINK*
Bob Entwisle in NJ
Hi Carol,
I googled 'bending brake video' and came up with several links that might clarify a bending brake for you, I've attached one here, but there are others as well.
hope this helps.
Bob in NJ
http://www.youtube.com/watch?v=Ytczt75-tqw
Thanks, Bob. I keep forgetting about YouTube.
Jason Waters
I just made one for my Unisaw. It had a side port with a 4" hose. I have been reworking my hook-ups, and upgrading to 6" ports. I used a 6" to 4"x10 (or was it a 12"?) straight boot from the ductwork dept of Lowe's. I then fit it to a piece of masonite (however, I would use 3/8 or 1/2 ply if I did it again). I'll try and take a picture. I used caulk and/or duct mastic to seal all joints. This is for the base. I don't have overblade dust collection, at least not yet.
I think it's easiest to start with one of these metal "boots" and make a plywood transition.
Try this approach *PICS*
wilbur
I have a 1940's era bandsaw that has zero amenities in the way of dust collection. I had one of those 4" plastic dust collector flanges, and was looking at the bandsaw, trying to figure out how to rig up the flange. I have zero experience with fabricating things from sheet metal. I was holding the flange thinking, "If there was only some way that I could make a dust collection device with this for my bandsaw. But whatever would I make it from?"
I was thinking this while staring directly at a pile of scrap pine sitting on the floor of my shop. Seriously.
A full ten minutes later: *** headslap ***
This is what I made.
I basically made this by screwing on the right side, putting it under the table of my bandsaw to see what I needed to notch out, then doing the same with the left side, then adding some cross pieces for strength.
On the right side I used a Forstner to drill some recesses, and sloppily epoxied in some rare earth magnets, which hold it in place.
And this is it in action.
This dust collecting shroud completely encloses the lower guides of my bandsaw, and collects the vast majority of the dust that used to pile up underneath the bandsaw. I can't put a number on it, but I wouldn't be surprised if this setup collects over 99% of the dust generated.
Although this setup is really custom fit for my bandsaw, the design principles should be easy to apply to any machine. It's basically a box to enclose where the dust is going and rare earth magnets mounted in an area where they can stick to the bandsaw.
After making this, I'm just a little surprised that more machinery accessories aren't made out of wood. We are woodworkers, aren't we?
Good one, Wilbur
And the magnet attachment feature means that you can take the shroud off when you have to tilt the table. That's fairly seldom in my shop, so the few times I'd be without a dust collection hookup wouldn't be a big concern.
Thanks for the dose of pragmatism, Doc.
Actually the blade gaurd that came with the saw does a pretty darn good job of corraling the saw dust on the top side. So no hood or hoses in the way on the topside. My saw is an old flex shaft drive Crapsman, so it seals up pretty tight and virtually all the dust goes down. Probably woudln't work with a Fancy cabinet saw, although I built a new mount and put and old Craftsman blade gaurd on th Griz cabinet saw at work and it corrals the vast majority of saw dust even without suction from the bottom. Ya know it's what I have so it's I use.
Duct work parts are your friend. Use Google and find an elaborate duct supply catalog. Look up "boots" and "take offs". Take offs are designed to fit on the side of a trunk duct and then connect to a (usually) round duct. They can be 4" or 6" or something else. Boots go on the termination end of the duct and transition from round to rectangular. A huge variety of configurations are available. Sometimes the rectangle is at ninety degrees to the duct and sometimes it lines up with it. I found four inch to 2 1/4 by 10" end boots to be very useful. You need access to the catalog and to a large supplier because there may be fifty different variations manufactured but Lowe's and the like only carry abut 10% of the them. I cobbled together my system and it ain't purty, but it works pretty well and was cheap.
Here's a picture of an End Boot on my bandsaw.
And a take off on my jointer, worked perfectly without any modification to either the jointer or the takeoff.
Re: Wood dust port ? Contractor's saw
Charlie Lenz
Last year I was trying to figure out how to make my Contractor's table saw dust hood for under the saw more affordable for people, and to where they could make one themselves out of easily obtainable materials. So I built one and was considering selling the plans to do it. But much like woodworking, I supose I'd be expected to give it away, or be labeled as a greedy jerk.
John McGaw
Yes, I've found that even the limited ductwork selection at the Borgs offers a lot of possibility for dust collection. Now that I've upgraded my shop to permanent ducting and blast gates I've got less use for the kludges I used to use the DC fitting on my homemade router table is still a modified duct coupling from Lowe's and it fits and works just fine. I just put in a 'Big Gulp' collector hood on my compound miter saw and got rid of that Borg-derived Masonite kludge.
Re: Making dust ports - part 2
Came home from the borg with a toilet flange, 2 adjustable metal elbows, a reducer, and a length of stove pipe. Now the fun starts. I'll let you know.
mdclor
Rube Goldberg would be proud of you! LOL :D
Re: Making dust ports - part 2 ( Carol )
Charlie Lenz
Carol, in your first post you mentioned that you need to make a side collecting dust port for your table saw. Out of curiosity what type of table saw do you have ? A cabinet saw ?
Larry in NW Ohio
Carol Yes Carol what kind of saw do you have indeed? Make sure you post a picture, I really want to see this saw you have that has a toilet flange in it. Yes this is going to be very interesting saw indeed or a new type of a way of resting in the shop.:D Larry
@ Larry: You will be pleased to know this will be the second saw with a toilet flange, keeping in mind that we are talking about the disposal of waste products and a toilet flange facilitates that function. Ahem! :D
@ Chuck: It is a Grizzly cabinet saw in this case.
@ Merle: Rube Goldberg is a blood relative. :)
Charlie Lenz
Carol, thats interesting. The older Deltas came out the side, and I just noticed in the Grizzly site that the Shop Fox does also.
