Cleaning Dishwasher (OT)
Larry in nw ohio
We have an 7-8 year old GE disher and have never cleaned it and I seem to remember a while back there was a post about cleaning one and of course at the time I didn`t think about it. I do remember that to use vineger, but I don`t remember how much and how to do it. Since it goes thru cycles and dumps inbetween them. Do you just run it thru just one cycle and when it dumps and then just let it run the whole cycle to clean the vinegar out. Thank You. Larry
Re: Cleaning Dishwasher (OT)
RobCarr
Here's what I would do... half a box of baking soda and a good cup of white vinegar and let it run a couple of cycles... I have a GE abut the same age, probably very similar to yours and it has setting like normal/pots/china/glasses/rinse, etc. I'd at least use the glasses setting and turn off drying and hi-temp rinse.
Dick Coers
If there is a lot of lime, I use about a half gallon of vinegar in a regular cycle with no dishes. Then I use about a cup in every dish load for a while. The glasses will really sparkle.
Larry in nw ohio
Dick I`m pretty slow to catch on things, so bear with me. Do you mean you put a cup in with the dishes when it fills with water then open it then throw the vinegar in and thenlet it run the rest of the cycle. It doesn`t give the dishes a vinegary smell. I wonder would do any good to put some baking soda in with the vinegar once in a while to keep things clean. Thanks Larry
Dave Nichols
We have iron in our water which stains the inside with a rust coloered stain. Too clean it we run Kool-aid lemonade powered mix through it. We just fill the soap container with the mix and run it through the normal cycle. It removes all stain and leaves the dishwasher smelling lemon fresh.
Larry in nw ohio
Dave I`ll have to remember that, I wonder if that could be put in with the dishes since it`s not a soapy type of powder.How did you ever come up with Kool Aid? I`ll have to tell my Son, he has a well and so much trouble with iron. Larry
Check your soap
paul in AZ
The newer versions of powdered soap are phosphate free. The lack of phosphates leads to a powdery film of hard white material on dishes, silver and the machine itself -including the pump. DAMHIK. That cost me a new machine.
There are now pellets of soap the size of the soap holder that avoid this deposit and leave dishes clean. they may seem pricey but at ~20 cents a load are worth it.
Dick Coers
The dishes can have a slight vinegar smell when I bring them out of the dishwasher, but I don't notice it when drinking from the glass or eating off the dishes. Our old machine used to start out with the pump running to purge any water left in it. Our latest machine does not. So I put in all the dishes, fill the soap compartments, then add the cup of vinegar in the bottom of the machine. Close the door and hit the button. Squeaky clean when it is done. I've never tried baking soda. It may have a slight cleasning action, but I thought it was used mainly as a product to release co2 to lighten baked goods. Not saying using it is wrond, but I don't see the advantage there.
Re: Check your soap
Jerry Gibbs
what is best for cleaning the film off the dishes by. vinegar by hand or something else?
Re: Check your soap
paul in AZ
I used the 3M Scotch Brite scrubbing cloths and liquid soap. I think thats what they are called. The cloth-like things about 6 inches square. Vinegar might make it easier but I didn't try that.
walta
The new phosphate free detergents will etch glass. The damage is permanent.
Look for “Cascade institutional dishwasher detergent” I found it at GFS stores.
It seem to be the old formula with phosphate.
Walta
Dave Nichols
If your going to use the Kool-aid you run it through without any dishes, the citric acid is what helps to clean the dishwasher
