Incra Miter Express quick review
Stephen Kirk
Ok, I've had several table saw sleds over the years. After getting the Jet Xacta saw 2 years ago I never got around to building a new sled. The time came, I needed something, but I just didn't feel like building another one and mucking with it to get it square. So, I looked around and decided to purchase the Incra Express.
I already have the Incra 1000SE, which is super accurate. The Miter Express, if you haven't seen it is a sled that the miter gauge fits into. Setup was easy, simply put the slide track in, adjust for a good fit, put the sled ontop and attach it, then cut it off to make it square, maybe 10 mins. There is a second piece to put on the opposite side to catch off cuts. In use, it's totally simple and accurate. I set mine so the slider is to the right of the blade, allowing me to use the length of the extension table and the fence as a stop (with a block, of course). With the miter gauge on the slide, it's easy to cut any angle you want. The sled has t track in it to accept hold downs, and those make things so much easier. There is even a support to hold the fence extension during long miter where it might flex. I put the t slides on so that the fence can't tilt out of the track. I have a good 24" of stable cross cutting capacity. Taking the miter gauge off the sled (or putting it on) takes about 2-3 mins and does need an Allen wrench. Want to add a sacrificial fence, no problem. The 1000 SE has a the extended fence and flip stop, making repeated cuts a snap. I use mine with the blade guard in place, Jet has stop where the sides raise independently, makes cuts a little safer.
Little pricey at around $150 but having a dead accurate sled with a lot of capacity and functions, set up in under 10 mins - worth it to me.
Yeah, I'm not associated with Incra in any way, just a happy customer.
