DIY tip for sander with vac / hose
Keith Newton
One thing I like least about using a random orbit sander with vacuum hose, is the weight of the hose pulling down, interfering with my sensitivity / dexterity.
I like to keep things simple when I solve problems. This time it was so easy, I couldn't believe it. I found an old surf-rod, which hasn't been used in 25 years. Right now, it is wire-tied to an old grocery cart, which came with my shop when I bought it, that I use for moving small parts around from station to station.
With a snap swivel attaching the line about 4' down the hose, I can just reel in enough tension to lift the hose to the right working height, and the rod tip about 6' up, I gain enough movement through rod flex to have a good range of motion.
I'm thinking I probably could cut a big hole through a big block of wood, which could be dropped into the vice on any of the workbenches around the shop. This would make a quick rod-holder at each of those stations to add a little more flexibility to the setup.
