We value your privacy.
I made the unfortunate mistake of breaking a mounting tab on the plastic switch box on my Unisaw and can't find a replacement part without buying an entire assembly. The switch box part number is 438-01-018-0199 but that is for the entire switch box for which is $190 to replace.
All I need or want is the back side of the plastic box with the new mounting tabs in place.
Anyone know of such a place that sells just the plastic box parts and not the entire switch assembly?
Brian I`ll take a stab at this, is there a way you could post a picture, maybe we could fabricate a part. I don`t suppose you could make a little piece of angle out of a thin piece of aluminum or the such? I have done many, and so have a lot of others, instead of buying. Good Luck. Larry
I have two of my Delta boxes held together with zip ties. Same thing happened to mine and I wasn't about to pay the piper what they wanted. Zip ties are quick and easy and of course reversable.
After opening the box and digging around a bit I think my best bet will be to just drill out a new mounting hole and attach the box to the bracket at the new point.
I just get anal sometimes about bringing things back to the way they were originally. Sometimes to a fault.
I can relate to that. However, sometimes your budget has more to say about practicalities than we'd like. If it were me and the same thing happened to my cabinet saw now, I'd probably replace it to keep it original. Years ago I would have probably resorted to the tie-wrap solution but plan to replace it later when I could better afford to.
The important thing is that the saw works no matter the fix. Perhaps you'll find a way to get that saw to make some extra money to pay for the original part.
They are awfully proud of their parts and accessories. I bought a new Delta 50-760 dust collector about two years ago. When I got it home I wanted to switch it over to 230V. I opened up the switch box and soon found out that it was only a 115V switch. After doing some research I find out that the Delta 230V switch for that DC was going to cost me $35 plus shipping ! Delta probably saved at the most $5 per collector going with a lesser switch. In my opinion what they charge for a Unisaw you shouldn't have to deal with some cheap plastic box, and then have to pay a rediculous price if you need a new one.
