REAL MILK PAINT
Another bandsaw issue
Thad Parker
After much frustration attempting to align the new blade, I discovered a missing "spec nut" on the lower wheel. This is the nut that holds the wheel on the shaft.
I suspect that the nut was missing when I acquired the saw, as the shop is currently clean and the nut is nowhere to be found.
My issue is this: assuming the saw ran for several month with no noticeable tracking issues w/o the nut, would I be fine going ahead w/o one?
It's an old Delta model 28-200, and the part can be found ($7.61). The issue is that it takes anywhere from a week or more to even ship to me, & I need some stock resawed yesterday.
No schematic discloses the thread-size of the nut, so I finding it locally would probably be out of the question.
Any thoughts?
Re: Another bandsaw issue
Jim Hager
I would order the part and wait for it before operating the saw. Think of the damage it would do if it were to come off during operation. Likely being the lower wheel it is held on with a key in the shaft but I still would not operate it until it is fixed. If you have a thread pitch guage you can measure the size and determine the pitch then go to a good hardware store and find one to fit it.
buy a bunch
Jerry Gibbs
of nuts and return the ones that don't fit or keep them to have around.
john Veerkamp
You can buy a screw gauge at most hardware stores, or as was suggested , buy several nuts of various sizes. Don't forget that there are both coarse and fine thread in inch measurement sizes as well as metric sizes. Also check that it's not left hand threaded. Any good hardware store that carries Hillman fasteners should be able to fix you up.
Re: Another bandsaw issue *LINK*
Thad Parker
I found a whole assembly for sale, that shows the threads to be .785".
That's nominally close to 2cm. I suppose that's why they call it "spec nut" on the schematic rather than list the actual size.
There wouldn't be metric parts on a Delta built in 1945 would there?
The nut I'm missing would be the one that goes on the right side in the picture I linked to.
Upon comparing part numbers, there is another "spec nut" on the other end of this shaft, so I could carry it with me to a hardware store.
I'll try to post results if I come up with a local replacement. I'm pretty sure these shafts are in a lot bandsaws out there.
http://www.sawcenter.com/shaft.htm
Kneale Brownson
That would be a 20 mm nut,  but
Kneale Brownson
try taking the one off the one end and put it onto the other end. The dimension on the other end is different so the nut size might be different too. That shaft has keyways on both ends, so you also need that to reinstall your wheel.
Jason Waters
I just rebuilt a Delta bandsaw, and I'll bet it not a real common nut. I seem to remember it being fine thread. It also has a shoulder on the inside to make contact with the wheel. You should order the right nut.
0.785 doesn't come out to be some US nut I recognize. I highly doubt it is metric, but one never knows.
Let us know if you find something that fits.
That's what I suspect...will keep u posted
If it's been running without the nut could you simply wrap some wire around the grooves real tight to keep the wheel in place. Check it frequently to see if it's slipping. I had a taiwanese copy of a Delta and the wheel came off one day. The only thing that happened was the blade slipped off and of course stopped immediately. The lower wheel just sat there and spun. I found the nut and put it back on with locktite.
I don't think there is a danger of being hurt but you could feasibly damage your workpiece. the wheels fit over the screw pretty snug some I think wire around the shaft would stop the wheel from coming off. It might come loose and let the blade wonder off which again could be bad for the workpiece.
larry in nw ohio
Thad I think John has a pretty good idea, maybe take some copper wire and a washerput the washer on , then wrap the wire around as close as you can to the wheel and if you have any room get a narrow hose clamp and put that on up against the wire. Now of course this is just temporary till you find a nut. Good Luck. Larry
