Re: OT: Removing Base Board
Jason Roehl in Lafayette, IN
I use a short prybar/cat's paw combo. Before I use it, I actually sharpen the wide end on my bench grinder. If the trim is painted, carefully run a utility knife along the top of the trim to cut through any caulk and/or paint.
Now, whether the trim is painted or not, there are a couple tricks for not damaging the walls. First is to get a 3-4" wide, stiff scraper. Put this on the wall just above the base with the handle up. You will pry against this. Next, work the sharpened pry bar in between the base and the wall with hand pressure only--don't hammer it. It's best to start in the middle of the piece of base at a nail, if you can find one, so that the base doesn't split. When you pry (push towards the wall), don't go for the home run--that is, don't try to pry it all the way off in that first location. Just get it a little bit loose, then move down the wall to the next nail and do the same thing--don't try to pry it all the way out. Gently "wiggling" the pry bar is more effective than pushing hard. It should take 3 or so passes over the length of the base to get it out far enough to get your hands behind it to where you can continue the wiggling with your hands. Again, don't try to pull it all the way off from one place.
Jason
