Cost to CNC cut *LINK*
Tom Dunlap
Take a look at this project.
If a person had the data for the CNC how much would it cost to hire time on a machine to cut the wood?
Are there shops that would take on 'off the street' work like this?
Tom
Chuck Box
Tom Dunlap
Tom
Chuck Box
Registration...
John in NM
Gotta be a member to see the pics. You might consider downloading them and then posting them here or putting them in a photobucket (or similar) account and linking to them.
As to CNC costs, I don't know a whole lot about wood shops. A friend told me he knows one in NC or somewhere that would do outside work as a job lot. In the metal world, another friend has this done routinely with small simple parts that would take him ages to make on a conventional machine. Others have told me its a lost cause to even look. I suspect its a question of actually doing the looking and not getting discouraged at the first couple "no's".
Of course, comparison between metal cnc production and wood is tenuous. There is far more demand for metal parts, and the programming and holding fixtures tend to be a little easier, due to the kind of thing being made.
I had considered building a cnc router to make the grips I sell, but decided that there was too big a learning curve (delay in supply) and that my volume was so
small and I'm fast enough carving them that I'm still better off working by hand (no significant cost reduction). Depending on the complexity of the box you're looking at, you may find a situation similar to mine.
Re: Cost to CNC cut
Carol Reed, Pahrump, NV
Suggest you go to CNCzone.com and ask for local cnc shops. Lots of variables here. Having the code is not as great a part of the whole equation as you might think. There are many formats out there. When I had the ShopBot, I used the same shop rate and it included set-up time, both software and hardware (hold-downs, etc.) plus pre-production and post-production work, materials and labor, overhead and profit. For one-offs it is not inexpensive. CNC's are intended to recoup cost of running them by many multiples of production runs. One-offs are much less expensive to just simply build without the CNC.
Running CNC's is lots of fun and I have thought about getting another one, but I have no products that justify the investment of time, money, and infrastructure. They are still lots of fun though, so one never knows.
John ...
Mike Farinella
Scroll down to see the pics.
Try 100K Garages *LINK*
Bill Earl
This is a registry that matches up ShopBot owners across the country with CNC projects.
100K Garages
Got it, thanks!
Re: Cost to CNC cut
Bruce, a MN Galoot
Two years ago I built a wine cabinet for my son and his wife. I found the part that held the bottles particularly daunting, highly fiddly, and so I called a local CNC company. They wanted $1K for the setup alone. It took a lot of time, but I did it myself.
Re: Cost to CNC cut
Robin Corell in Atascadero CA
There is a shop near me that makes solid body guitars on a CNC router and also does outside jobs. He charges $60/hr, same price for programing, set up, and cutting.
Robin
Re: Cost to CNC cut-thx Robin
Tom Dunlap
That's what I was looking for.
I ran a tree care company for 25 years so I understand pricing. Getting a rough idea of the cost of a project is all that I'm looking for. My guess is that someone could bring in the data in a compatible format along with a sheet of plywood and walk out the door with project parts and it would be quite reasonable.
Tom
