Lumber rack ideas please.
Gary Evans
Hi all,
I'm getting ready to build some lumber racks in my pole building. I have some ideas, but am looking at options. Quick to build is a big consideration. I have plenty of 2x4's to frame with. I seem to remember seeing lumber rack pictures a long time ago on here so I'll look around for those. Any other input would be appreciated.
I want to be able to store 16' boards and remove them from the front of the racks. The racks will anchor to a line of 4-4x4 treated posts on 4' centers. Posts are buried with tamped gravel at the base and attached to the roof above.
Thanks,
Gary
Re: Lumber rack ideas please.
Re: Lumber rack ideas please. *LINK*
John McGaw
To me, easy is an overriding concern. This has been working for me since 1998.
LV Rack
Paul Blackwell
Go to this website: www.thewoodwhisperer.com/racking-my-brain and there is a video on how to build a wood rack using 2 x 4's and 3/4 plywood. There is a downloadable plan. I'm currently building one, and it looks like a good rack.
Jim Hager
I think I'd drill a series of holes large enough for 3/4" pipe in your 4x4's at a slight angle and insert the pipe into the posts. You'll need to make a jig so all of them are exactly the same height and angle ( you can use one of your 2x4's for the jig. You can put a lot of lumber on a 20" length of pipe and if you don't need a row you can take out the pipe and store it until you do.
wooden leg
That is exactly what I did. My only problem is I had to put higher then what I wanted, so I have to use a ladder for the upper row. I drilled the holes the same size of the pipe and had to use a hammer to put the pipe in the holes. Dave
"H" racks
Bill Tindall
Capture a single horizontal 2 x 4 between two vertical 2 x 4 posts. Use 2- 1/4" bolts to secure the horizontal piece. these sections are 42" wide and hold about 500 bdft each. You could make a 49" wide section for plywood.
Mine are spaced 4' apart with the back section 2' from the back wall. If you begin with a layer of 12' lumber the racks will then hold anything 8 to 16'.
We used this style racks for 30 years when we sold hardwood lumber. What you see in the picture are the left overs from the business.
Re: "H" racks
Stuart Johnson
Does anyone use a vertical rather than horizontal system? Mine is a LV or Rockler system like the link posted. It works well but is a pain unless you want the top one or two boards on a row. Bill's holds a lot of wood, allows for, I forget the term (flitch) storage but it also looks like you have to unload a complete section to get to some of wood. I don't think you could store as much in the same space standing up but then not many of us mortals have a stash like his.
How to use the rack.....
Bill Tindall
One species is stored in each section. Lets us say you are building a cherry table top. I set up two sets of horses and start removing lumber from the rack. Rejects for whatever reason (usually inefficient cuttings among defects, lengths or widths) go on one horse and possibilities on the other. When the "keeper" pile has accumulated sufficient lumber to make the top I take another look at it to be sure. The "rejects" go back into the rack. For something like a table top where I want the best possible outcome I may empty the rack. It is hardly a significant fraction of the total time to build something. Plus it is good to reacquaint one's self with the inventory.
If I was storing smaller quantities then I would make the horizontal supports smaller and space them for only a few layers of lumber. If one has plenty of room a shorter rack for the inevitable accumulation of shorts is handy. I have a shots rack that is located under the stairs.
If anyone is into woodworking for the long haul there is much to be said for buying several hundred bdft of your preferred wood when the timing is right. For example, Europe was a strong market for our cherry and the quality of what remained for domestic use got exceptionally bad. The export market has tanked. Upon my last visit to a lumber mill I saw cherry for sale as good as 30 years ago. Instead of piddly 5-6" widths with lots of sap there was lumber over 12" in packs of top grade cherry. On the other hand walnut is in high demand and this might not be the best time to buy a pack of walnut unless it looked especially good. The bottom line is if an opportunity to buy a large quantity of lumber turns up, seize it if you have the money and space.
With much to choose from there will be little waste on a project. Lumber has been an excellent investment. Quality continues to deteriorate. All good reasons to invest in lumber.
Re: "H" racks
roger lance
I'm reminded of a line from the movie Butch Cassidy and the Sundance Kid...."Think that was enough dynamite there Butch?".....think that's enough wood there Bill? :D .....your point about buying a high quantity of a favorite wood when the price is right is a good point.
Re: "H" racks
Alan in Little Washington (NC)
I'll be contrary here. IF you have the headroom- forget a horizontal rack and go vertical with wood stacked "soldier style" edges towards the wall. Benefits:
  • Requires almost no structure
  • Easy and quick to build
  • The floor supports the weight
  • Easier AND SAFER to load and unload (no step ladder or stool required to reach high boards). Safety chains recommended however.
  • Can easily examine both sides of all boards
  • Any board can be selected- no re-stacking needed to get "the" board at the bottom of a stack
  • Doesn't take any more space, actually less, than a horizontal rack
  • No warping if wood is 20% MC or less. A few "average" woodworkers do it that way- Sam Maloof, David Marks, Lon Schleining, many Woodcraft stores, etc.
    I and many others store vertically:
  • Re: Lumber rack ideas please.
    roger lance
    another wall rack in a basement....
    Gary Evans
    Now this is more what I have in mind, except that I intend to angle the outriggers downward slightly to make it easier to examine boards. Are the outriggers captured in a triple support? That's my hold up at the moment. Joining 2x4 outriggers to existing 4x4 posts so that they will support maximum weight.
    Thanks for the ideas so far. Bill, I like your rack, but I need to put everything up on one wall to make more usable floor space.
    Gary
    question
    Bill Tindall
    Why do you have sticks between your layers of lumber?
    I have a stick fetish....
    roger lance
    please tell me it is totally unnecessary and I will stop it....in addition to taking up space, stickering can be a PIA....I've talked to various lumber guys around here and they indicated that it was a good practice (did not say necessary practice) when storing lumber....however, this lumber is kiln dried (not air dried) and I am open to giving up my fondness for sticks. Although, an argument could be made that stickering helps the boards acclimate to the shop before working with them??
    That is just part of it
    Bill Tindall
    There is a smaller rack to the right, a 7' tall pile of walnut that isn't in a rack and a stack of poplar drying that is outdoors. Indeed it is more lumber than I will ever use but the trouble is I don't know what of it I may use. I got rid of 500 bd ft of figured mahogany some years ago because it didn't sell well at the time and I thought I would never make any formal Period furniture. Then countries put an export ban on mahogany and making Period furniture got popular. Now people would drive a long ways to get some the the mahogany I once had. I had to beg and pay an arm and a leg get 75 bdft for a class I took a couple of years ago.
    After that experience I am hording anything that isn't easily replaced. Some years back I did some consulting on an environmental problem affecting a saw mill that dealt exclusively with walnut. I didn't intend to bill them anything as they had been a reliable supplier for many years for which I was grateful. As it happened they had just sawed some veneer grade walnut logs for a special order. The owner told me to go pick 500 bdft of walnut as a reward for saving their butt. I chose carefully. Each of those racks has a similar story. The bottom line is that any time I have encountered a good deal(price, figure or quality) I seize it. This philosophy can extend to getting one extra board that looks especially nice when just buying a small quantity for a specific project. That board will be in your pile not someone else's when you need it.
    That said, if one works a few hundred bdft of lumber each year, over the course of a lifetime you use up a lot of lumber.
    Answer
    Bill Tindall
    That is the only dry lumber I have ever seen stored(that would be "stored" not "drying") on sticks. You will have to take it on faith that I have seen millions of bdft stored.
    Typical stored KD lumber- dead packed and banded.
    Bart Goldberg
    Bart Goldberg
    I purchased this Rack System and have it installed inside my garage. They are really strong. I have a huge amount of lumber stored on them and they install easily and work well.
    Bart
