Going to order a new clamp or two....
John in NM
From Wetzler.... really just to see if they're still around... last time it came up I don't remember anyone knowing for sure. From a thread at SMC I'm a little hopeful, and it seems maybe the summer months are not a good time to order.
I need to replace my broken one (a few years ago I was abusing it mightily while trying to pull 500' of field fencing tight - enough force I had to pull off my big truck as the little one would roll before the fence was tight (ok, it's old and has lousy compression, but so does the big one :D ) I have since worked out some better ways of hooking a winch to fencing :D
Re: Going to order a new clamp or two....
Dale Lenz
Dale Lenz
Good luck and let us know if they are still around. I've got several Wetzler's clamps that I got off of E-Bay, I do like using them.
Bruce, a MN Galoot
Well, that's an innovative use of a clamp, but I'm pretty sure that's why fence stretchers were invented. I didn't think the clamps had that much travel, but maybe my imagination is failing me (night shift this week). :D
Yeah, trouble with being in a hurry.... *LINK*
John in NM
I do dumb stuff instead of figuring out that there must be a right tool and someone must make it :D
This fence was maybe 6 horizontals with vertical ties all sold in a roll. Might be called hog fence too, I can't remember. The idea was to keep all the horizontal wires the same tightness without buying however many wire grips would be needed. So I clamped a couple 2x4's together, pinching the fence and proceeded to pull that tight against the truck using a come along. What broke the clamp was hooking the winch to it and pulling.
I'm not sure anyone I know has the proper tools for fencing, a lot of them seem to just patch stuff together out of what's at hand. One day I'll buy some wire grips, those look pretty indespensible, and save wear and tear on my woodworking stuff :D
Here's the right way to grip wire... not even as pricey as a clamp... ah hindsight...
wire grip
Re: Yeah, trouble with being in a hurry....
gary camp Bend, Oregon
For "Hog" wire or No climb I use two 2X4's bolted together and a pair of cable come-a-longs hooked to the 2bys with small (5/16") chain. For single wire I have a ratcheting wire fence stretcher that has built-in wire grabers, kinda reminds me of a sideways bumper jack. I haven't had much luck with wire / cable grips on noclimb, the vertical wires are too close together. More opportunity to buy tools, I mean who doesn't need a come-a-long or three.
glc
For what it's worth...
I designed Wetzler's website about eight years ago, and it is still on the Internet, BUT, I have not had any dealings with Kevin and Joan (the owners) since then. Unfortunately, the webmaster@wetzler.com still points to me, and I'm unable to change it. As a result, I have received many angry letters from disgruntled would-be customers, some of whom had actually paid in advance for clamps but never received them. I have tried to communicate with the owners to get my address taken off their website, but I can't connect with them in any way. It is a total mystery to me, as I thought I heard rumors that they are still selling clamps, exactly how I can't imagine.
So, I would suggest proceeding with caution.
Re: For what it's worth...
Larry in NW Ohio
Ellis Would it do any good to ask someone here if they would live fairly close, if you know where there are located, to go over and stop by maybe and see if they could find out what the story is. Larry
Yep, understood...
John in NM
I saw some discussion of this in a SMC thread, and one of the posters from 2010 did live close by and had been to their shop.
I'm willing to risk the $30, I really like the 9 I've got. If I get the replacement reasonably soon, they'll get a positive note here - which they sorely need :D
I've seen this sort of thing before, small vendors being too busy to talk to customers. Used to be they could get away with it as long as they delivered, but with all of us hanging around on the web and talking a blue streak, I think there is much less tolerance for it now. Ease of broad communication makes reputations very fragile.
Re: Yep, understood...
Jason Waters
John,
It seems like in this case they didn't always deliver or Ellis wouldn't be getting these emails.
But if they do come through for you, it would be good to know.
The other thing I keep hearing...
John in NM
Is that deliveries get very slow in the summer months (vacation) and if they're starting a new production run. I'm not sure I've heard yet of anyone actually getting stiffed, just waits on the order of a couple months with no communication.
I will definitely relate what happens here.
