THE WOODRAT IS BACK!
Needing to buy a new RO Sander.
Keith Newton
I'm favoring the Bosch 1250DEVS 6-1/2-Amp 6-Inch Random Orbit Sander with Vacuum Port, but looking at the photo, there appears to be a little arrow on the nose, just above the pad, indicating counter clockwise rotation, as you look down from above. This would be just the opposite of all other sanders and grinders that I have ever used.
I was wondering if this is true, or if I mis-interpeted the arrow, and or if the CCW rotation takes some getting used to?
Also, Im wondering if Hook and Loop is the only option? I have too much inventory of adhesive backed to abandon.
Re: Needing to buy a new RO Sander.
H&L vs PSA
Hi Keith,
I can't testify about that particular sander, but I've owned other 6" Bosches in the past, and they were generally excellent in all respects. Personally, nowadays I prefer hook and loop disks only because I can reuse them easily. PSA tends to be better in production environments where you use the disk until it's done and then change it.
I wouldn't think that CCW rotation would be hard to get used to, though it might not be intuitive for a while. I'd actually be surprised if the rotation is not the normal rotation we're all used to, but it's worth hearing from other users about it.
Robin Corell in Atascadero CA
I have a Bosch 1295D and until I just checked I had no idea that it turned ccw. I had a Porter Cable before this but I have more hours with a souix or dynabrade air DA. The CCW has been a non-issue for me. I still prefer air over electric for speed but a high quality air DA is way moe expensive than a good ectric sander.
Don't know about the availability of a PSA backing disc but I do know that they make three different 6" H&L backing discs: soft, medium, hard. The soft is great for chair seats.
Robin
I had an old 6 B&D RO PSA sander, then purchased a 5" Porter Cable (also PSA) marked down at Lowes - didn't have dust collection so I purchased a Bosch 5" H&L. Since then I have bought a couple of more Bosch, (needing to use more than one at a time when we made all my son's woodwork for his house). I also have an air ROS (NAPA) bought at an auction for less than $20. Other than the transition from PSA to H&L and the dust recovery of the Bosch units I didn't see any difference in use in any of the units. Don't know if they rotate a different direction or not - can't see how it would affect the sanding method or action. By the way I really prefer the H&L - can change and reuse disks on small jobs. I have had to purchase a couple of new pads over time but think they are well worth the difference. I do like to use scrapers but have changed to sanding for big jobs like woodwork.
Thanks Ellis, Rob, and Larry.
Keith Newton
No I don't suppose that rotation direction matters on RO, but in the other mode, if it is tilted up on edge, the dust would be sent back toward my face, rather than down and away. However, I don't expect to be using it in that mode much.
The biggest thing that worries me, is that lots of the sanding I do, is along edges, and corners. If I can do a side, then tilt over knocking off a corner, then run down an edge, then spin on around all sides like a drawer, without ever turning off, there is a certain way to tilt the pad, and move, without hitting something that rags out the edge. I hope that isn't affected, or I'll be bitching.
I may just go ahead and order another PC like the one I've been using, when my helper returns in a couple of months. I do have a Sioux 3" which is handy for detail work, but there are plenty of times that we could use two.
Jason Waters
Keith,
I recently was going to replace my old PC 333VS, but I found the part I needed to fix it. However, my conclusion was to buy a reconditioned Bosch (I missed them at like $50 for a 5") based on what is available today. I have used Bosch's and DeWalt before, and always liked the Bosch too.
My favorite is the Right Angle old Porter Cables though.
Now, I only use Hook and Loop. I hated PSA discs when I got my sander, but I can see in a shop where you don't change why you might want them.
Most makers you can buy either pad for the bottom. A place like Klingspor or Amazon might have the pad. I got the last one for my PC from Amazon.
