We value your privacy.
Thought I'd get a tread going where people would show some of their shop made projects that make working in the shop more effective and pleasant. So here are some photos of my down draft table which was made to directly hook to my portable vac....
and some looks at the top....
and the funnel that directs the dust to some fittings under the table to the vac....
and a view of the grid that makes the top....
this table was an advancement in dealing with dust....as was my recent move to a ROS with hook and loop and 8 hole dust collection. Thanks for looking.
I once considered building such a unit, until my friend advised that if I got the sander with good dust collection, then I would not need a down draft table.
I hook up my Bosch or Rigid sanders to my Fein shop vac and I have zero dust. For my use, I prefer dust collection at the source.
Dave....I agree but I was SLOW to come to a ROS with dust collection....I just got my Bosch a couple of months ago and I also bought the Bosch hose that hooks directly to this sander and my wet-dry vac....thats a good combination....got to fight dust however we can....I still have my PC 5" no hole ROSs, so the table helps there but if you have not moved to a ROS with 8 hole built in dust collection capability, I certainly recommend that you do.
The table looks good, but thats no vacuum, it's a 2 stage dust collector. And if I may suggest, do what you have too to get the CFM killing sharp bends out of the DC hose.
Thanks Charlie for your correction of terminology....it makes all the difference....as for those CFM killing bends in the hose, the vac....2 stage dust collector....was attached to the table and moved close for photo taking to show how the table is powered....speaking of which, when that 2 stage dust collector is turned on, much of those CFM killing bends in the hose become minimized.
I have a Down draft table I made from what should have been the roll around base for my DC. (the DC is located in a closet outside the shop and does not roll.) I was thinking of using a furnace blower fan to power the unit. That requires lots of filters to filter the air and return it to the shop without the dust. Then I decided to hook it to the DC instead. I put a tray under the top that tapers from about two inches deep to about six inches. There is a hole in the side for a DC hose. Made a grid top, not as nice as yours. Because the tray is shallow I have storage under it for short scraps. The whole thing rolls under the wing of my RAS when not in use. Your hopper shape may work better, but I should would miss the extra storage space.
You can improve the performance further by putting sides on it and even a hood over the top. These could flip up when in use and fold down when not. I have not done it permanently, but have temporarily clamped a sort of mock up on it and it does help. With a wide open top the volume of air is spread so thin the velocity is low and some dust may escape.
It gets a lot of use for sanding and for glue ups and assembly.
