fixed my Air Compressor
About ten years ago I bought a Sears Air Compressor used for $50 as a backup. I started remodeling homes and my main Air Compressor went out on the jobs. The backup came into play in my shop and has been in use for about five years. About two weeks ago it just quit. Checked it out and found out the pressure switch was the problem. Tried for a replacement locally, but no go, had to order it from Sears. Got tired of waiting and talked to a friend of mine who told me to remove the pressure switch and check the orifice in the bottom of it. Since mine is outside in a closet attached to the exterior of my shop his thought was that condensation got to it and rust the orifice closed. I was reluctant to do it because I would have to stand on my head in the closet out there in the cold and with no assurance it would work, I ordered the replacement. The Sears guy on the phone talked me into buying a belt while I was at it. They sent the belt but said the switch was on back order. They keep sending E-mails with "up-dates" reminding me it is on back order and that they are glad to be of service. So, It was pretty warm outside today and I attacked the compressor. Figured I had nothing to lose, you can't break something that is already broken, and I needed to remove the switch to put the new one on anyway. Finally got it off and cleaned the orifice with a tiny drill bit and put it back on. Good as new. Now I should cancel Sears slow service.
This is just a tiny gloat and I thought I would share in case somebody here has the same problem.
