We value your privacy.
Finished up the back splash tile this weekend. With 9 outlets and switches, 3 windows and three counter top heights there were as many cut tile as whole tile involved. Tedious.
As one can see the white switch plates that looked fine against the formerly painted wall look quite out of place on the grey tile. Can they be successfully sprayed with Krylon or some such paint?
I would buy a can of the color I want and try one. Before painting I would rough up the exposed surface with some 320 or 220 grit sand paper. Apply two coats following the instructions on the can. Wait 2-3 days and see how the paint holds up. If the paint seems to adhere, paint the rest of them otherwise go buy one new switch plate.
You could paint the plates with little problems, but what about the outlets? I suspect that painted outlets would "look" like you had painted them after a few appliances had been repeatedly plugged and unplugged.
They look ok to me, and I think you would be better off just leaving them as they are.
You might be able to get gray plates and fixtures (outlets, switches). I've never used the business linked below, but it lists gray plates; and, if that's so, an electrical supply house (or a good hardware store) might have, or be able to get, them, too.
We had some outlets and plates that had been painted when we moved into our house, and they looked pretty shabby.
Check out the collection of faceplates at your local Big Box Store. I found some composite plates that look like granite that would probably coordinate very well with your Kitchen colors.
I have painted more than a few (at least partially) by accident and a few more intentionally. Regular interior latex (emulsion for our UK brethren) sticks to most plastic wall plates pretty well although most will let go under heavy scrubbing. I've had the best luck by roughing up new unsullied plates a bit with steel wool to take off the shine and then shooting them with auto-type primer from a spray can. After than most any paint could be applied and will probably be permanent.
I have painted a bunch of them. I prime them with a good spray bomb primer like Kilz and then I use the wall color latex. Mine are the regular old plates made of plastic. No issues yet (some are 10+ years painted). Our wallpaper hanger covered a bunch too. He did a fantastic job (he even covered an ac vent!).
There are clear plates available that allow wall paper to be inserted inside. These can be wiped claen with no degradation of the wallpaper. The same can not be said about wiping clean a painted plate.
Another possibility is craft shows where hand made ceramic plates can be found.
When we did the tile back splash we ordered a switch plate made out of the same tile as the back splash.
I'm sure is was pricey, but there is only one switch plate through the back splash, all the outlets are Wiremold, hidden between the top of the back splash and the bottom of the cabinets.
Might be worth a call to your tile store to see about tile switch plates.
They can and the plates can look good. The outles on the other hand...
I strongly suggest that you just upgrade them. Leviton makes many different colours. It's rather silly in my opinion to spend all that money, time and effort on the kitchen and then to skimp on inexpensive outlets and plates.
Here is a link to show the differing colours available for outlets. Browse the site and you may find some very pretty plates too (I used the A&C ones myself because they fit my decor
I have no affiliation with HOAH but am a satisfied customer over a few years
Bill, my day job is electrician. When the plates are to be painted we install ivory metal plates with a krinkle finish. They are made to be painted and come out beautiful, no chipping. When the plastic or nylon ones are painted they tend to chip DAMHIK. They are very cheap.
