Source for "L" brackets?
I have to do a bit of "bracing". The privacy panel for the first pews in the church are a bit wobbly. I'd like to find brackets to brace the panel.
Preferably "antique brass" or "bronze" colored and about with legs about 3" long.
TIA
Re: Source for "L" brackets?
Larry in nw ohio
JL You might try VanDykes.com, they have all kinds of things like that. Good Luck. Larry
Another approach,
Keith Newton
JL, I did some church work last year, which had the same problem. I can't help you with those brackets, but they ripped up the carpet under the communion rail, then laid tile. It was my job to fasten it down. Drilling through that tile destroyed the bits that I was using, so I taped off the floor with masking tape, as well as the bottom of the rail, then raised it up high enough to use a heavy bed of silicone under it, then let it down onto it.
I left some 1/8" shims under there to keep from smushing it all out. I figured I could always go back and add brackets later, but after the silicone dried, it was obvious there was no need for anything else.
If you don't find the bronze braces, I would look into welding up something, and painting it. There are some good realistic looking paints, which should pass inspection for something at floor level.
I imagine that your church, like most, runs on a tight budget. Lee Valley has some nice brackets, but they're pricey ($12.50 or so each).
You can, of course, just get your basic "L" brackets from the hardware store, and paint them.
I hadn't though about Amazon. They have some nice brass ones and some nice brass colored ones.
John McGaw
The brackets in question are common Stanley hardware items and can probably be found anywhere -- Amazon is just acting as a middleman for a small hardware store on this one AFAIK. You might be able to find the identical item at a better price if you look around a bit. The important thing is that the size is not what you originally asked about but I know that these brackets are quite strong when applied properly and they have been holding failing chairs together for a long time -- I figure that these brackets or something essentially identical have been around longer than I have.
