H&L Sanding disk questions
I bought some of the Diablo sanding disks from Home Depot. Whatever weight the backing paper is, its too stiff and within seconds the edges start to crumble. The problem other than that is that if you remove the disk and then try to reinstall it, something has happened to the fuzz and the disk just falls off the sander. I am using a Porter Cable 5" ROS and my first thought was that the disk on the sander was worn out, so I installed a new one. Works great on a new disk, but won't hold a used one at all. I never had this problem with other brands. Anyone had a similar experience? Any advice?
